查看: 169|回复: 2
I bought a chain truck..I want to use straps and remove most of the chains.
 楼主| 发表于 2019-1-28 11:35:54 来自手机 | 显示全部楼层 |阅读模式
{"text":"I just bought a Cottrell CX10 High rail CHAIN. I plan to strap a majority of my operable vehicles and only want to keep chains on the truck where they will remain useful. I plan to be picking up inops from Copart and IAA at times but am not sure which positions on my trailer and head rack to leave chains at for the inops. I need recommendations on which decks positions to leave the chains on for those unique scenarios. Thank You\n","pics":"[]","canComment":true}
发表于 2019-6-28 10:20:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"convert it so you can have both","replyToPid":0}
发表于 2019-8-14 06:32:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Give it a few loads and play around with it.. you’ll be able visualize where to keep chains a lot easier. \n\nIf you haul a lot of fords and GM trucks probably a good idea to keep most of your chains. ","replyToPid":0}
GMT+8, 2026-4-17 23:49 , Processed in 0.075200 second(s), 23 queries .
