查看: 442|回复: 27
Placards?
 楼主| 发表于 2019-6-5 23:00:24 来自手机 | 显示全部楼层 |阅读模式
{"text":"I was told this load requires placards on the trailer, but a hazmat endorsement isn’t needed. \nCould this be right? \nLast load that I hauled with a little hm, didn’t require placards because it was under a certain weight of the material, nor did it require the endorsement. \n\nWhy would placards be needed?","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-6-5 23:54:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"Placards on HAZMAT can’t go through cities or local streets! In my opinion PLACARDS=HAZMAT=ENDORSEMENT ","replyToPid":0}
发表于 2019-6-6 07:19:48 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"got an answer for you from the Hazmat expert in the state of Washington. according to the gal who works for the Federal motor carrier safety Administration you are not required to be placarded for class 9 and you dont need a hazmat endorsement for class 9. for any questions on hazmat materials she said you are welcome to call 360-753-9875."}
发表于 2019-6-6 00:01:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"Also a hazmat endorsement is NOT required for class 9 even if placards are on..\n\nhttps://www.phmsa.dot.gov/regulations/title49/interp/14-0102","replyToPid":0}
发表于 2019-6-5 23:27:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Sounds to me like u don’t need em ","replyToPid":0}
发表于 2019-6-5 23:07:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"LOL.","replyToPid":55339}
 楼主| 发表于 2019-6-6 00:26:02 来自手机 | 显示全部楼层
89722 发表于 2019-06-05 15:58:46 class 9 will not need a placard if hauled in the domestic us. only to Canada or Mexico must placards be ran. We haul hazmat a lot being LTL and we dont toss them on in class 9.
","text":"Thank you","replyToPid":55388}
发表于 2019-6-6 01:28:32 来自手机 | 显示全部楼层
665437 发表于 2019-06-05 16:25:40 I know that I do not have the endorsement.
","text":"There will be an “HM” or “X” next to items on your BOL that need a placard because of weight or volume requirements. Usually an obvious notation or remark about it towards the top of first BOL page","replyToPid":55429}
发表于 2019-6-6 01:30:54 来自手机 | 显示全部楼层
665437 发表于 2019-06-05 17:14:08 I’m guessing it’s because they are such small pieces of plastic?! Would be quite a mess. \nAs much as I didn’t want to, I put the stickers on.
","text":"Some Plastics are toxic, flammable, hard to put out when on fire I’d guess","replyToPid":55495}
发表于 2019-6-6 06:10:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"I tried posting the thing for the FMCSA §177.823 but truckers path says it has to be reviewed for faul languge.","replyToPid":0}
发表于 2019-6-6 04:42:54 来自手机 | 显示全部楼层
{"replyToPid":55510,"replyTo":"
366847 发表于 2019-06-05 17:30:54 Some Plastics are toxic, flammable, hard to put out when on fire I’d guess
","text":"I had to haul a load of plastic beads once. some kind of filter media. thg hey said it had to be placarded due to specific gravity lower than water, so they flow, and fish will eat them"}
发表于 2019-6-5 23:03:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"what's the required placard?","replyToPid":0}
 楼主| 发表于 2019-6-5 23:11:57 来自手机 | 显示全部楼层
89722 发表于 2019-06-05 15:03:47 what's the required placard?
","text":"Class 9. My instructions say, they are not required due to a dot exception. Then  says, make sure to place them on the trailer. \nLoad is just plastic beads, I believe. ","replyToPid":55337}
 楼主| 发表于 2019-6-5 23:29:14 来自手机 | 显示全部楼层
654793 发表于 2019-06-05 15:27:17 Sounds to me like u don’t need em
","text":"That’s what I’m thinking. Putting them on the trailer seems like a way to get stopped easier, for an unwanted inspection. ","replyToPid":55356}
发表于 2019-6-5 23:58:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"class 9 will not need a placard if hauled in the domestic us. only to Canada or Mexico must placards be ran. We haul hazmat a lot being LTL and we dont toss them on in class 9.","replyToPid":0}
发表于 2019-6-6 00:21:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you’re wondering if you need a HM license then you probably don’t have one. If you did you’d know where to find the needed information and what books you need to have on your truck while pulling HM. Anything that needs placards is a load needing an HM license, hence the HM placards. Call your safety department. ","replyToPid":0}
GMT+8, 2026-4-18 02:31 , Processed in 0.113248 second(s), 24 queries .
