查看: 47|回复: 0
2016 UTILITY 3000R
 楼主| 发表于 2020-5-20 14:15:05 来自手机 | 显示全部楼层 |阅读模式
TrailerThread
typeOfNeckV2:
carsV2:
liftgateV2: -
halfRoundV2: -
stingerV2: -
extendableV2: -
floorTypeV2:
flipAxleV2: -
frameTypeV2:
equipmentStatusV2:
statusDetailsV2:
acquisitionDateV2:
certifiedUsedV2: -
previousOwnerV2:
titleRequiredV2: -
titleReceivedV2: -
contractV2: -
forConsigmentV2: -
consignorV2:
roofTypeV2:
hydraulicTailV2: -
buttomLoadV2: -
vaporRecoveryV2: -
axleTypeV2:
pneumaticSizeV2:
compartmentsV2:
includeForkliftV2: -
{"text":"2016 Utility 3000R with Carrier X4 7500 reefer with 7,xxxhrs, Disc Brakes, Air Ride, Air Slide, Right Weigh Load Scale Gauge, Fuel Saving Skirts, Bendix Eversure 3030 Air Brake System, TABS-6 Advanced ABS with Roll Stability, Hendrickson Vented Axles, Meritor PSI Tire Inflation with Thermalert, Right Weigh Load Scale, Hendrickson ULTRAA-K Slider System with Zero Maintenance Dampening, Bendix Disc Brakes, Stainless Steel Corner Posts, UTM Barrier Design Double Swing Stianless Steel Diamond Pattern Rear Doors, Anti-Theft Tamper Proof Hardward, Recessed swing door holdback, Heavy Duty Extru Alum Wedge Type Rear Thershold w/4 Dock Board Guide Plates, Veritex Wall Lining, Grote Supernova and Trucklite series LED lights, Side Skirts, and more...","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0}]","canComment":null,"externalShare":false}
GMT+8, 2026-4-3 08:35 , Processed in 0.062452 second(s), 25 queries .
