查看: 55|回复: 0
2014 WABASH Arcticlite
 楼主| 发表于 2020-5-20 14:13:03 来自手机 | 显示全部楼层 |阅读模式
TrailerThread
typeOfNeckV2:
carsV2:
liftgateV2: -
halfRoundV2: -
stingerV2: -
extendableV2: -
floorTypeV2:
flipAxleV2: -
frameTypeV2:
equipmentStatusV2:
statusDetailsV2:
acquisitionDateV2:
certifiedUsedV2: -
previousOwnerV2:
titleRequiredV2: -
titleReceivedV2: -
contractV2: -
forConsigmentV2: -
consignorV2:
roofTypeV2:
hydraulicTailV2: -
buttomLoadV2: -
vaporRecoveryV2: -
axleTypeV2:
pneumaticSizeV2:
compartmentsV2:
includeForkliftV2: -
{"text":"2014 Wabash Arcticlite with Carrier X2 2500 with only 12,xxxhrs, Meritor Tire Inflation PSI System, Right Weigh Load Scale, Side Skirts, HUB piloted system with longer studs for Dual Tire application, Bendix TABS-6 ABS System, Air Ride Suspension, Hendrickson HKANT 40k Air Ride Slider System, Stainless Steel Diamond Pattern Rear Door Panel, Forklift Reinforcement, Versitex-Utility Wall Linking, and more...","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0}]","canComment":null,"externalShare":false}
GMT+8, 2026-4-3 08:35 , Processed in 0.251054 second(s), 25 queries .
