查看: 232|回复: 16
All broke down truckers report for duty!
 楼主| 发表于 2020-5-16 01:27:09 来自手机 | 显示全部楼层 |阅读模式
{"text":"got red stop light, check eng light, abs, coolant light, fuel restriction light, regen light all on. Christmas came early \n \nGo to regen, stops after 2mins. tried many things. was suppose to be home tonight. 2 days off. rip\n \nanyone have some fresh memes to share?","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1512.0,\"name\":\"\",\"url\":\"\",\"width\":2016.0}]","canComment":true,"externalShare":false}
发表于 2020-5-16 02:35:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"its a  Frieghtliner what do expect","replyToPid":0}
发表于 2020-5-17 07:09:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"DEF and EGR delete and problem solved! $ 4500","replyToPid":0}
发表于 2020-5-16 07:13:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"\nYou need to do a parked regen. but first you gotta clean the carbon out of your fuel doser valve, my nîgga. The son of a bîtch won’t regen with those stop lights on.   also top off coolant level, check oil, and check trailer .\nYou’re probably a company driver for some Schmuck low budget company any way if you let all this happen. ","replyToPid":0}
发表于 2020-5-16 02:27:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"Have you changed the fuel pump at all or regen doesn’t work because of the Knox sensors Freightliner have the tendency to light up like that but the problem is either low fuel supply or bad inlet and outlet Knox sensors most common and broken fuel pump hopefully not ","replyToPid":0}
 楼主| 发表于 2020-5-16 05:36:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"650k miles, it's a 2015","replyToPid":0}
发表于 2020-5-16 04:30:01 来自手机 | 显示全部楼层
911712 发表于 2020-05-15 18:35:30 its a  Frieghtliner what do expect
","text":"except it's an engine problem, cummins or detriot, which is used in most or all of the different truck brands you idio t.","replyToPid":372644}
发表于 2020-5-16 04:01:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Engineknox and truckerknox couldn’t hear it.","replyToPid":0}
发表于 2020-5-16 02:15:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"your truck  doesn't  work right","replyToPid":0}
发表于 2020-5-16 02:18:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"You broke down","replyToPid":0}
发表于 2020-5-16 02:24:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"How many miles you got on this truck ","replyToPid":0}
 楼主| 发表于 2020-5-16 05:35:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"update, interstate repair truck here. dtf filter is horrible condition. bunch of error codes he cleared. wont force regen. we unplugged battery for 15 mins, now its regening. \n \nappreciate the replies, been a rough week.","replyToPid":0}
GMT+8, 2026-2-11 15:57 , Processed in 0.060284 second(s), 24 queries .
