查看: 421|回复: 15
my dinosaur! (Ugliest truck ever?)
 楼主| 发表于 2020-5-15 23:58:57 来自手机 | 显示全部楼层 |阅读模式
{"text":"1989 Peterbilt 372 s60 detroit 9 SPD 3.36 rears.\n9-11 mpg loaded. ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1051.0,\"name\":\"\",\"url\":\"\",\"width\":1080.0}]","canComment":true,"externalShare":false}
发表于 2020-5-17 02:11:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"I like odd trucks no one else has. I would drive that.","replyToPid":0}
回复 支持 9 反对 0
发表于 2020-5-16 03:00:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"9-11 mpg? I call B.S.","replyToPid":0}
回复 支持 2 反对 5
 楼主| 发表于 2020-5-16 03:10:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"lThe Peterbilt 372 was designed for high efficiency and driver comfort, this was the most aerodynamic Peterbilt cabover ever built. The nose piece of the cab flipped forward (similar to the old 350 COE of the 1950s) allowing access to maintenance items. The 372 was in production from 1988 until 1993. The 372 proved that 10+ MPG can be achieved with a class 8 truck. The truck has the distinction of being the most unusual Peterbilt design offering a sinister Darth Vader look that some also thought looked like a football helmet","replyToPid":372649}
回复 支持 7 反对 0
发表于 2020-5-16 08:37:45 来自手机 | 显示全部楼层
962976 发表于 2020-05-15 19:10:02 lThe Peterbilt 372 was designed for high efficiency and driver comfort, this was the most aerodynamic Peterbilt cabover ever built. The nose piece of the cab flipped forward (similar to the old 350 COE of the 1950s) allowing access to maintenance items. The 372 was in production from 1988 until 1993. The 372 proved that 10+ MPG can be achieved with a class 8 truck. The truck has the distinction of being the most unusual Peterbilt design offering a sinister Darth Vader look that some also thought looked like a football helmet
","text":"I still call BS too","replyToPid":372652}
回复 支持 0 反对 5
 楼主| 发表于 2020-5-16 01:43:54 来自手机 | 显示全部楼层
147103 发表于 2020-05-15 16:34:59 no it's not ugliest truck. international setback axle cabover. has that place. I drove truck like that. for a year.
","text":"ok your right int setback is uglier lol","replyToPid":372602}
 楼主| 发表于 2020-5-16 01:47:00 来自手机 | 显示全部楼层
960965 发表于 2020-05-15 17:44:08 I actually like they way they look, they just need a modern day upgrade with exhaust emissions.
","text":"no thanks I like to be able to work on my truck without computer diagnostics or paying a dealer","replyToPid":372623}
禁止发言
发表于 2020-5-16 00:34:59 来自手机 | 显示全部楼层
发表于 2020-5-16 04:36:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"or the plastic hõmõ Lonestar","replyToPid":0}
发表于 2020-5-16 04:25:25 来自手机 | 显示全部楼层
962976 发表于 2020-05-15 18:01:07 ? I'm going to assume you were talking to jedusisliberal?
","text":"Yeah, oops ","replyToPid":372630}
发表于 2020-5-16 01:58:15 来自手机
{"replyTo":"","text":"Are you fùćkíng dùmb? ","replyToPid":0}
支持 1 反对 1
发表于 2020-5-16 01:10:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"Looks kind of like a football helmet","replyToPid":0}
 楼主| 发表于 2020-5-16 01:44:27 来自手机 | 显示全部楼层
954189 发表于 2020-05-15 17:10:04 Looks kind of like a football helmet
","text":"That was a nickname for them football or Darth Vader.","replyToPid":372609}
 楼主| 发表于 2020-5-16 02:01:07 来自手机 | 显示全部楼层
954189 发表于 2020-05-15 17:58:15 Are you fùćkíng dùmb?
","text":"? I'm going to assume you were talking to jedusisliberal?","replyToPid":372629}
GMT+8, 2026-4-16 05:14 , Processed in 0.166446 second(s), 25 queries .
