查看: 224|回复: 2
Question for the seasoned drivers
 楼主| 发表于 2020-5-12 12:33:51 来自手机 | 显示全部楼层 |阅读模式
{"text":"I’m about to run through the Rockies for the first time on I-40. Picking up a load here in OK bound for Cali. My question is, what can I plan on per hour average speed wise? 45? \n\nIf it helps I’m a solo driver with a major carrier and my truck (18 cascadia) is limited to 65 and locked in economy mode. My load should be about 20,000. \n\nI’m trying to figure how much time to plan for out of ABQ, so I can visit family there but still get my load to the final on time. Thanks for any assistance drivers!","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-5-12 16:40:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"A truck should be managed at an average speed of 50 mph.\nThat gives you extra time for your coffee break and fuel stop.\nAlways averag yourself at that speed until you get a better handle on how to manage your time.\nGood luck.","replyToPid":0}
 楼主| 发表于 2020-5-12 17:33:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"@JesusWasLiberal - Thanks for the heads up. \n@Cam - I always plan on 50 when trip planning. I was wondering if I needed to plan on extra time for this route. Thanks for the response though.","replyToPid":0}
GMT+8, 2026-4-18 05:25 , Processed in 0.081965 second(s), 24 queries .
