查看: 193|回复: 30
Gender isn't black and white
 楼主| 发表于 2020-5-10 04:32:59 来自手机 | 显示全部楼层 |阅读模式
{"text":"npr.org","videos":"[]","link":"{\"picture\":{\"description\":\"\",\"height\":800.0,\"name\":\"\",\"url\":\"https://media.npr.org/assets/img/2020/03/09/trh_podcast-tile_sq-c05fb259465d433a5cf8a21248b8fa209a6b7690-s800-c15.png\",\"width\":800.0},\"title\":\"TED Radio Hour : NPR\",\"type\":\"GENERAL\",\"url\":\"https://www.npr.org/podcasts/510298/ted-radio-hour\",\"valid\":true}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-5-10 08:18:55 来自手机 | 显示全部楼层
958225 发表于 2020-05-09 21:20:17 \"the biology of s x\".\n\n1 hour, good listen. For the conservatives who don't have the attention span, it's a story about a inters x person with a vag but no uterus, no periods, and testicles.
","text":"I encourage you to listen to Ben Shapiro.","replyToPid":368562}
回复 支持 5 反对 2
发表于 2020-5-10 06:43:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’m not wasting my time listen to that garbage! It’s nothing to do with trucking. It’s a post by someone with mental issues.","replyToPid":0}
回复 支持 6 反对 1
发表于 2020-5-10 08:16:29 来自手机 | 显示全部楼层
958225 发表于 2020-05-09 22:04:57 If that's the only way to get conservatives to actually read or listen...that's a great idea. We could even start a news channel that reports fake news but pretends to be a real news organization, and we'll call it Fox.
","text":"We already have that.. it’s called CNN 😆 ","replyToPid":368571}
回复 支持 5 反对 1
 楼主| 发表于 2020-5-10 07:02:06 来自手机 | 显示全部楼层
945419 发表于 2020-05-09 22:59:54 Maybe if world is lucky.  You will get mental help
","text":"you should try bashing your head against the wall, can't get any worst.","replyToPid":368592}
回复 支持 1 反对 5
 楼主| 发表于 2020-5-10 06:28:15 来自手机 | 显示全部楼层
959827 发表于 2020-05-09 22:12:51 All news outlets are biased and exaggerated, and they’ll keep pumping their poison out as long as folks continue to feed off them to fuel their own particular biases.
","text":"there's a difference between being biased and being a propaganda machine, Fox news is propaganda.","replyToPid":368575}
回复 支持 1 反对 5
发表于 2020-5-10 08:22:14 来自手机 | 显示全部楼层
","text":"What do you identify as?","replyToPid":368562}
回复 支持 4 反对 1
 楼主| 发表于 2020-5-10 06:54:57 来自手机 | 显示全部楼层
945419 发表于 2020-05-09 22:51:55 You need mental help! Freak
","text":"I think you're the one that needs it, but sadly educational funds aren't going to help you as you're past critical developmental stages. I can only wish you a speedy.and painless covid death.","replyToPid":368588}
回复 支持 1 反对 4
 楼主| 发表于 2020-5-10 06:50:15 来自手机 | 显示全部楼层
945419 发表于 2020-05-09 22:43:07 I’m not wasting my time listen to that garbage! It’s nothing to do with trucking. It’s a post by someone with mental issues.
","text":"😂. You are a prime example of how to stay stewpid. The person actually has a physical gender difference, not just an identity issue. If you can correlate that physical differences are precursor to genetic differences, then you can understand why certain people have gender issues. it's like an invisible illness, very much like Lyme disease, and Covid. but I bet you don't believe that either... except gender spectrum isn't a disease, anymore than your small deck Republicanism is.","replyToPid":368585}
回复 支持 1 反对 4
 楼主| 发表于 2020-5-10 06:38:38 来自手机 | 显示全部楼层
945419 发表于 2020-05-09 22:31:01 Yes I know what side I’m on. The side of realistic. Biology determines your gender.. Not someone with mental issues
","text":"obviously you did not listen to the story...you can't fix stewpid, but you can eliminate it.","replyToPid":368581}
回复 支持 1 反对 4
发表于 2020-5-10 06:31:01 来自手机 | 显示全部楼层
958225 发表于 2020-05-09 22:25:08 in that case, you're either born smart or dumd, and I guess you know what side you're on. There's actually an infinite, near infinite, combination of genetic sequence so your belief of male or female, is not even close to reality.\n\nbut if yes or no is all you understand, stick to it you flat Earther.\n\nand there's only so much you can talk about relating to trucks, how about you grow a brain and stop being one dimensional. I feel sorry for anybody married to you, They must be very desperate.
","text":"Yes I know what side I’m on. The side of realistic. Biology determines your gender.. Not someone with mental issues","replyToPid":368577}
 楼主| 发表于 2020-5-10 05:20:17 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"\"the biology of s x\".\n\n1 hour, good listen. For the conservatives who don't have the attention span, it's a story about a inters x person with a vag but no uterus, no periods, and testicles."}
回复 支持 0 反对 3
发表于 2020-5-10 06:02:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"Sounds riveting. Maybe they’ll put it in the next Marvel or Star Wars movie. ","replyToPid":0}
 楼主| 发表于 2020-5-10 06:04:57 来自手机 | 显示全部楼层
959827 发表于 2020-05-09 22:02:01 Sounds riveting. Maybe they’ll put it in the next Marvel or Star Wars movie.
","text":"If that's the only way to get conservatives to actually read or listen...that's a great idea. We could even start a news channel that reports fake news but pretends to be a real news organization, and we'll call it Fox.","replyToPid":368569}
回复 支持 0 反对 5
发表于 2020-5-10 06:06:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Gender is what sèx you identify as, such as màlè... fèmàlè... etc\n\nBlaçk...whitè...Hispaniç ..is your race. \n\nJust thought I should clear that up!","replyToPid":0}
 楼主| 发表于 2020-5-10 06:09:10 来自手机 | 显示全部楼层
Gender is what sèx you identify as, such as màlè... fèmàlè... etc Blaçk...whitè...Hispaniç ..is your race. Just thought I should clear that up!
{"replyToPid":368572,"replyTo":"
960031 发表于 2020-05-09 22:06:03 Gender is what sèx you identify as, such as màlè... fèmàlè... etc\n\nBlaçk...whitè...Hispaniç ..is your race. \n\nJust thought I should clear that up!
","text":"black and white in this context meaning one or the other, no correlation to race. just thought I'd clear that up too."}
回复 支持 0 反对 4
发表于 2020-5-10 06:10:12 来自手机 | 显示全部楼层
","text":"No, it’s how you pull liberal virtue signallers to the theaters, so they can show everyone how woke they are. ","replyToPid":368571}
发表于 2020-5-10 06:12:51 来自手机 | 显示全部楼层
","text":"All news outlets are biased and exaggerated, and they’ll keep pumping their poison out as long as folks continue to feed off them to fuel their own particular biases. ","replyToPid":368571}
发表于 2020-5-10 06:20:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"This has nothing to do with trucking. Just a bunch of trash. Your either born male or female! ","replyToPid":0}
 楼主| 发表于 2020-5-10 06:25:08 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"in that case, you're either born smart or dumd, and I guess you know what side you're on. There's actually an infinite, near infinite, combination of genetic sequence so your belief of male or female, is not even close to reality.\n\nbut if yes or no is all you understand, stick to it you flat Earther.\n\nand there's only so much you can talk about relating to trucks, how about you grow a brain and stop being one dimensional. I feel sorry for anybody married to you, They must be very desperate."}
回复 支持 0 反对 4
GMT+8, 2026-2-11 22:52 , Processed in 0.088173 second(s), 24 queries .
