查看: 206|回复: 21
Inflation
 楼主| 发表于 2020-5-8 09:11:30 来自手机 | 显示全部楼层 |阅读模式
{"text":"A red line from my box that inflates the trailer tires is cut. Is it necessary if the tires are inflated properly ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-5-8 10:14:21 来自手机 | 显示全部楼层
958892 发表于 2020-05-08 02:08:03 Yes dude and it depends what tires it’s . Usually if it’s steering tires then definitely check them and air them if they need one. But under inflated tires are likely to explode or cause fire . And they can also decrease your fuel economy
","text":"Ummm you are an idiôt","replyToPid":367998}
回复 支持 9 反对 0
发表于 2020-5-8 13:57:41 来自手机
{"replyTo":"","text":"Just where the fcuk do you people come up with thus siht?","replyToPid":0}
支持 5 反对 3
发表于 2020-5-8 10:16:02 来自手机 | 显示全部楼层
","text":"Automatic tire inflation systems are for the trailer only, which is what he said. ","replyToPid":367998}
回复 支持 8 反对 0
发表于 2020-5-8 13:56:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have yet to see an under inflated tire \"explode\".","replyToPid":0}
回复 支持 3 反对 3
发表于 2020-5-8 20:08:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"I love getting and apparently keeping your attention 😘😘😘","replyToPid":0}
发表于 2020-5-8 19:54:32 来自手机 | 显示全部楼层
959827 发表于 2020-05-08 10:42:00 Hmm...pretty lame. What was your previous profile name? I thought you may be a new adversary, worthy of debate for the sake of my own entertainment but now I’m almost certain you’re just another mongoloid who finally figured out how his phone works.
","text":"The only one lame here is you and the identity crisis you seem to be having. Are you male or female or tránsgénder?","replyToPid":368124}
发表于 2020-5-8 20:23:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"An under inflated tire will not explode. A dam near flat tire can break the bead.\nThere is a big difference between an explosion and a pop.\nAn under inflated tire can overheat, will be damaged, cause excessive wear and so on.","replyToPid":0}
发表于 2020-5-8 20:54:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"You sound like acuseme Right now!","replyToPid":0}
发表于 2020-5-8 17:11:17 来自手机 | 显示全部楼层
211886 发表于 2020-05-08 05:56:49 I have yet to see an under inflated tire \"explode\".
","text":"I've seen and heard it happen right in front of me. they pop Because they unseat the bead.","replyToPid":368031}
发表于 2020-5-8 18:21:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"And that 9 minutes was spent on a trucker app. Smh 🤦‍♀️ ","replyToPid":368116}
发表于 2020-5-8 10:08:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yes dude and it depends what tires it’s . Usually if it’s steering tires then definitely check them and air them if they need one. But under inflated tires are likely to explode or cause fire . And they can also decrease your fuel economy ","replyToPid":0}
发表于 2020-5-8 10:15:01 来自手机 | 显示全部楼层
{"replyTo":"","text":"Lol why 😂","replyToPid":368005}
发表于 2020-5-8 14:59:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'm hoping soviet union is being sarcastic here.","replyToPid":0}
发表于 2020-5-8 15:11:30 来自手机 | 显示全部楼层
612134 发表于 2020-05-08 06:59:14 I'm hoping soviet union is being sarcastic here.
","text":"Doesn’t sound like it.  That’s the knowledge base that’s out here now","replyToPid":368079}
发表于 2020-5-8 16:31:18 来自手机 | 显示全部楼层
960031 发表于 2020-05-08 07:11:30 Doesn’t sound like it.  That’s the knowledge base that’s out here now
","text":"You need to go to Knowledge Base and enlist, cretin. 🤣🤣🤣","replyToPid":368087}
GMT+8, 2026-2-11 15:57 , Processed in 0.084525 second(s), 24 queries .
