查看: 60|回复: 0
2014 UTILITY 3000R
 楼主| 发表于 2020-5-6 14:11:09 来自手机 | 显示全部楼层 |阅读模式
TrailerThread
typeOfNeckV2:
carsV2:
liftgateV2: -
halfRoundV2: -
stingerV2: -
extendableV2: -
floorTypeV2:
flipAxleV2: -
frameTypeV2:
equipmentStatusV2:
statusDetailsV2:
acquisitionDateV2:
certifiedUsedV2: -
previousOwnerV2:
titleRequiredV2: -
titleReceivedV2: -
contractV2: -
forConsigmentV2: -
consignorV2:
roofTypeV2:
hydraulicTailV2: -
buttomLoadV2: -
vaporRecoveryV2: -
axleTypeV2:
pneumaticSizeV2:
compartmentsV2:
includeForkliftV2: -
{"text":"2014 UTILITY 3000R with CARRIER X2 2500A 11,xxx HOURS, Corrugated side Panels, UTM Barrier double Swing rear door with stainless steel diamond pattern, Bendix TABS-6 ABS system, Meritor Tire Inflation system include Thermalert, Rightweigh Load Scale, Hendrickson HKANT 40k Airride/slider system, Deep Heavy Duty Extru Alum Bottom Rails, Airride Suspension, Bendix Versajust Automatic Slack Adjusters, Versitex-Utility Wall lining, LED lights, Forklift reinforced bearing grid at rear with full length alum I cores, and more.","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0},{\"description\":\"\",\"height\":768.0,\"name\":\"\",\"url\":\"\",\"width\":1024.0}]","canComment":null,"externalShare":false}
GMT+8, 2026-4-3 10:17 , Processed in 0.056371 second(s), 26 queries .
