查看: 428|回复: 14
Are weight stations looking at logbooks ?
 楼主| 发表于 2020-5-4 22:49:18 来自手机 | 显示全部楼层 |阅读模式
{"text":"Driving thru nc to va to Delaware ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-5-5 00:12:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'm sure he meant elogs beaches","replyToPid":0}
回复 支持 2 反对 3
发表于 2020-5-5 02:23:28 来自手机 | 显示全部楼层
593861 发表于 2020-05-04 16:48:49 if you get pulled in for overweight or some other violation they might and probably will especially in Virginia. Virginia is always open. Just make sure your weights good and pre-trip it for you go in keep your eyes front and don't make eye contact
","text":"actually Virginia has been closed for a couple weeks everywhere on 81 that I've been to and they're letting you park there overnight or for your 10-hour break","replyToPid":366940}
发表于 2020-5-5 05:11:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’ve been running HOS exempt for multiple weeks now. Midwest to NYC/Philly/Boston.. haven’t crossed a scale the entire time.\n\n🇺🇸🇺🇸🇺🇸","replyToPid":0}
发表于 2020-5-6 07:40:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"Don’t know why y’all say log books aren’t used I use loose leaf every day ","replyToPid":0}
发表于 2020-5-7 01:14:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"nah but if they do I will record it wit muh sail fone & get him to say sum tin’ rayciss’ ","replyToPid":0}
发表于 2020-5-5 07:53:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"i had a level 1 inspection in California. i was over my 70 and over my 14. they never even looked, never asked. i had called them and the one in Wyoming just to get a general consensus before and they both said they weren't enforcing it at the moment. but i was still worried when they did my level 1 cause you never know","replyToPid":0}
发表于 2020-5-4 23:21:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Logbooks haven’t been used in over a year.","replyToPid":0}
发表于 2020-5-4 23:55:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"you still use logbook?","replyToPid":0}
发表于 2020-5-5 00:48:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"if you get pulled in for overweight or some other violation they might and probably will especially in Virginia. Virginia is always open. Just make sure your weights good and pre-trip it for you go in keep your eyes front and don't make eye contact","replyToPid":0}
发表于 2020-5-5 01:02:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes.","replyToPid":0}
发表于 2020-5-5 07:42:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"No, but the DOT officers 👮 👮‍♀️ inside them are. ","replyToPid":0}
GMT+8, 2026-4-18 07:02 , Processed in 0.127869 second(s), 24 queries .
