查看: 194|回复: 16
Which is cheaper?
 楼主| 发表于 2020-5-2 21:40:22 来自手机 | 显示全部楼层 |阅读模式
{"text":"I have some wiring problems in my truck. TA Loves or Flying J. which has cheaper hourly rates ? tia.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-5-2 22:58:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"Buy one replace it yourself ","replyToPid":0}
回复 支持 7 反对 0
发表于 2020-5-3 01:54:41 来自手机 | 显示全部楼层
934400 发表于 2020-05-02 15:35:36 Yes, it’s pretty simple.
","text":"Lol yeah it’s basically open the plastic bag it comes in/unplug the old/plug in the new... even 50% of Swift drivers can handle this one 😆 ","replyToPid":366041}
发表于 2020-5-3 04:42:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Are you f¥©k ing r€tard€d?\nHow did you make it this far in life???","replyToPid":0}
发表于 2020-5-3 03:21:33 来自手机 | 显示全部楼层
956792 发表于 2020-05-02 17:54:41 Lol yeah it’s basically open the plastic bag it comes in/unplug the old/plug in the new... even 50% of Swift drivers can handle this one 😆
","text":"Well I’m not a swift driver but I am a female and yes it’s pretty easy. I’d say if you can’t replace this , you shouldn’t be driving a truck.","replyToPid":366101}
发表于 2020-5-2 23:05:09 来自手机 | 显示全部楼层
646385 发表于 2020-05-02 14:41:53 oops. I meant to type electrical wiring problem* More specifically the electrical cord running to the trailer is faulty (ibthink)
","text":"If it's just an electrical pigtail, just about every truck stop sells one. You can replace it yourself.","replyToPid":366024}
发表于 2020-5-3 03:17:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"Take it to the dealer for this the truck stops actually don’t know much about it.they will only fix it halfway. Dealer will cost more but you will know it’s done right and you don’t have to get it towed there .","replyToPid":0}
 楼主| 发表于 2020-5-4 10:02:44 来自手机 | 显示全部楼层
211886 发表于 2020-05-02 20:42:13 Are you f¥©k ing r€tard€d?\nHow did you make it this far in life???
","text":"ligma nuts. No wonder your real parents left you. They were ashamed since they were brother and sister. You incestuous puck","replyToPid":366140}
发表于 2020-5-2 22:32:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"Flying J & Loves don’t really to a lot of that type of work, so it’s either TA or a dealer. ","replyToPid":0}
 楼主| 发表于 2020-5-2 22:41:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"oops. I meant to type electrical wiring problem* More specifically the electrical cord running to the trailer is faulty (ibthink)","replyToPid":0}
 楼主| 发表于 2020-5-2 23:08:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"is it as simple as it seems ? I checked online and couldnt find any videos","replyToPid":0}
发表于 2020-5-2 23:29:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"I seen more stuff at TA than the other ones","replyToPid":0}
发表于 2020-5-2 23:35:36 来自手机 | 显示全部楼层
646385 发表于 2020-05-02 15:08:40 is it as simple as it seems ? I checked online and couldnt find any videos
","text":"Yes, it’s pretty simple.","replyToPid":366029}
GMT+8, 2026-2-11 22:34 , Processed in 0.117033 second(s), 24 queries .
