查看: 172|回复: 15
Virus
 楼主| 发表于 2020-5-1 20:22:17 来自手机 | 显示全部楼层 |阅读模式
{"text":"If air comes thru a mask, does anybody really think a virus can’t?!!","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-5-1 21:25:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"N95 means it filters 95% of contaminants.. just use caution/common sense I guess 👌🏻 ","replyToPid":0}
发表于 2020-5-1 21:04:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"YOU ARE CORRECT\nWOW!!! FINALLY A SMART TRUCK DRIVER\nYOU SHOULD BECOME A SCIENTIST AND SUCH\nSTOP WAISTING YOUR HIGH IQ AT SWIFT\nJOIN HOLLAND ENTERPRISES","replyToPid":0}
发表于 2020-5-1 21:13:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"The n95 mask are designed to prevent that. The molecules are different sizes.","replyToPid":0}
发表于 2020-5-2 00:58:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"How many microns in size is the COVID-19 virus?\n\nThe COVID-19 virus is approximately 0.125 Micron or 125 nanometers in diameter.  (Source: National Library of Medicine)\nHowever, it often travels in biological aerosols from coughing and sneezing which range in size from 0.5-3 Micron.\n\nthis again on whether or not masks work, they do not for this particular virus. they will however stop you from projecting your sneeze onto the someone else. as far as actually stopping you from breathing the virus itself, you're trying to filter out sand with a Cyclone Fence. it's not going to happen. The Masks are mostly propaganda in design more than anything else to keep people afraid so that they listen to the government and do what they're told to do. just like gloves,  just like social distancing. keep them home, keep them broke, control the food, control the Sheep","replyToPid":0}
发表于 2020-5-1 22:33:30 来自手机 | 显示全部楼层
940979 发表于 2020-05-01 13:35:10 if I wanted to pee on you and had no pants my pee would travel freely to your leg. if I wore pants(or a mask) my pee could not travel to your leg.  if we all wear pants we can't pee on each other
","text":"I like the way you think! Now do one with pooping, so I can bust this nut ","replyToPid":365595}
发表于 2020-5-1 22:14:03 来自手机
957178 发表于 2020-05-01 14:04:26 it's not as fun as u think 44 isn't her age it's the circumference in inches of her \"ClittyCat\"
","text":"NAVY LÌZARD 👅🥗","replyToPid":365609}
支持 2 反对 0
发表于 2020-5-1 21:35:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"if I wanted to pee on you and had no pants my pee would travel freely to your leg. if I wore pants(or a mask) my pee could not travel to your leg.  if we all wear pants we can't pee on each other","replyToPid":0}
发表于 2020-5-1 22:32:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"a cloth isn't meant to 100% protect you, but it does minimize the air circulation and slow the spread, but I don't care, kill yourselves, so long as the economy is back open.","replyToPid":0}
发表于 2020-5-1 22:04:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"it's not as fun as u think 44 isn't her age it's the circumference in inches of her \"ClittyCat\"","replyToPid":0}
发表于 2020-5-1 21:33:33 来自手机
{"replyTo":"","text":"they keep your nasty breath from traveling around you.... masks are meant to prevent the wearer from spreading it, not from receiving it.","replyToPid":0}
支持 1 反对 0
发表于 2020-5-1 21:58:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have a KN95 mask with an air port, it's double cloth with removable .2 micron filters which filter out virus particles.","replyToPid":0}
发表于 2020-5-1 22:02:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"aww man I only have a hepa filter","replyToPid":0}
GMT+8, 2026-2-10 08:46 , Processed in 0.084705 second(s), 24 queries .
