查看: 601|回复: 13
Ohio Hwy 20 & Hwy 2. Has anyone used these highways?
 楼主| 发表于 2020-4-29 12:34:20 来自手机 | 显示全部楼层 |阅读模式
{"text":"Has anyone used these two highways in Ohio to avoid their tolls? Can a trucker use them or are they not meant for semis?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-4-29 12:49:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"both good non toll routes 2 is quiet more scenic.","replyToPid":0}
发表于 2020-4-30 08:08:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Take Route 30 across Ohio ","replyToPid":0}
发表于 2020-4-30 01:13:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can take Hey 2 all the way to o Cincinnati, but it will add about 4 hours to drive time going through from Toledo to Cincinnati.  Hwy 20 is your better road.","replyToPid":0}
 楼主| 发表于 2020-4-29 12:57:23 来自手机 | 显示全部楼层
954781 发表于 2020-04-29 04:52:28 I paid $20 last year from Perrysburg to Milan...There is no toll from Cleveland to PA line
","text":"ok i appreciate it, I'll take the 90. thanks","replyToPid":364668}
发表于 2020-4-30 05:40:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"buy an atlas","replyToPid":0}
发表于 2020-4-29 19:48:49 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Google Ohio turnpike fare calculator and put class 5 truck"}
 楼主| 发表于 2020-4-29 12:53:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'm sure it is but I'm looking to go through Ohio as quick as i can without getting robbed too much","replyToPid":0}
 楼主| 发表于 2020-4-29 12:48:47 来自手机 | 显示全部楼层
954781 发表于 2020-04-29 04:46:41 Hwy 20 is better but will take you through small towns. Use I-90 it's around $20, not expensive compared to NY.
","text":"only $20? I'll be driving the whole way through with a basic 5 axle","replyToPid":364659}
发表于 2020-4-30 14:46:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"2 to 250 to 224.  drops you out at the truck stops at seville(lodi).  at 71 and 76.  used to run that all the time.  company I was with wouldn't pay OH tolls.","replyToPid":0}
GMT+8, 2026-4-17 07:14 , Processed in 0.098748 second(s), 24 queries .
