查看: 78|回复: 2
lost boost pressure
 楼主| 发表于 2020-4-28 10:36:29 来自手机 | 显示全部楼层 |阅读模式
{"text":"Can anyone think of a possible solution to a loss of boost pressure. I've changed the sensor, had the turbo tested and still having an issue. It works fine for a while then check engine light comes on and no boost. Does that for a bit, then check engine light won't go off and no boost. turbo is still spooling up, just with power ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
 楼主| 发表于 2020-4-30 12:55:29 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yeah, twice now just to be certain. Still having issues today, but the latest mechanic said with the three hours I gave him to try and do the best diagnostics he could to rule out as much as possible. We're almost certain that it's nothing but a wire issue, especially after we see the cheapest quality wire a manufacturer can use","replyToPid":0}
 楼主| 发表于 2020-4-28 10:53:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"with less power","replyToPid":0}
GMT+8, 2026-4-17 12:54 , Processed in 0.282138 second(s), 25 queries .
