查看: 385|回复: 11
question I was about to change to a new company and is it a good idea to give notice to my current employer?
 楼主| 发表于 2020-4-28 09:58:02 来自手机 | 显示全部楼层 |阅读模式
发表于 2020-4-28 12:05:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"It's always good to give at least a two week notice.","replyToPid":0}
回复 支持 5 反对 4
发表于 2020-4-28 13:30:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"small company, advise them. big company, they don't care, millions of drivers.","replyToPid":0}
发表于 2020-4-28 21:50:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"At the absolute minimum, request time off. As soon as you pick up your load going home, send in your resignation, letting them know you're going to drop it off at the terminal. DO NOT say anything negative on Social Media about your last position until you're officially driving for Company #2.","replyToPid":0}
发表于 2020-4-28 21:31:16 来自手机 | 显示全部楼层
625878 发表于 2020-04-28 02:03:52 That all depends on what type of morals you have.\n\nYou do you, and do what makes you happy
","text":"If you care about your name and reputation give a notice.","replyToPid":364140}
发表于 2020-4-28 19:35:33 来自手机 | 显示全部楼层
{"replyTo":"","text":"They don't give you a 2-week notice when they decide to let you go... Take truck to terminal, tell them you have some business at home to take care of and can't park truck at home anymore. Clean out truck, take pics. And after you get that last check, let them know unfortunately you're not returning. Just let the new company you're discreetly leaving old company - most of the time, they'll understand.","replyToPid":0}
发表于 2020-4-28 16:57:00 来自手机 | 显示全部楼层
{"replyTo":"","text":"don't take truck home. take it to the terminal and clean it out there.  take a few pics to show it is at terminal and cleaned out.  maybe a small vid showing condition of truck and location where it is. If you take it home they might put an abandonment of equipment on your dac, which may screw you with the next company.  Take it to terminal and document,  document,  document. Good luck.","replyToPid":0}
发表于 2020-4-28 16:52:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"Give them a 2 week notice always leave in good terms just in case it doesn’t work out with the other company you’ll always be welcomed back to where u just left. Plus they will not give u a bad reference if the new company calls them. ","replyToPid":0}
发表于 2020-4-28 16:53:06 来自手机 | 显示全部楼层
798649 发表于 2020-04-28 08:38:59 Thanks for your help. I drive for a big company. So, Is it better to request home time and let them know after I received my full paycheck? On my other concern who is gonna pick up the truck after I went home?
","text":"If you don’t return the truck to them at the terminal they will charge you for abandoning the truck. Will screw up your DAC report.","replyToPid":364183}
发表于 2020-4-28 19:11:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"anyone who doesn't return it where you got it, you are unaMerican","replyToPid":0}
 楼主| 发表于 2020-4-28 16:38:59 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Thanks for your help. I drive for a big company. So, Is it better to request home time and let them know after I received my full paycheck? On my other concern who is gonna pick up the truck after I went home?"}
GMT+8, 2026-4-18 02:32 , Processed in 0.134717 second(s), 24 queries .
