查看: 249|回复: 7
TA or loves
 楼主| 发表于 2020-4-27 06:02:19 来自手机 | 显示全部楼层 |阅读模式
{"text":"Does TA has better diesel ???","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-4-27 07:37:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Loves is worse. Pilot is better.\nPeople will say it's all the same cause it comes out of the same pipes on the loading rack.\nI say it's not the same.\nInside info... I haul the chemical addatives that are put into diesel.\nLoves cut back on theirs. Smaller micron filters get clogged easier, and you'll get worse mpg, and your truck may seem sluggish running loves fuel.","replyToPid":0}
 楼主| 发表于 2020-4-27 07:07:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"Wow thanks for sharing some knowledge.","replyToPid":0}
发表于 2020-4-28 21:57:25 来自手机 | 显示全部楼层
211886 发表于 2020-04-26 23:37:54 Loves is worse. Pilot is better.\nPeople will say it's all the same cause it comes out of the same pipes on the loading rack.\nI say it's not the same.\nInside info... I haul the chemical addatives that are put into diesel.\nLoves cut back on theirs. Smaller micron filters get clogged easier, and you'll get worse mpg, and your truck may seem sluggish running loves fuel.
","text":"Same with gasoline. All gasoline comes from the same refinery, whether Shell, RaceTrac, BP, etc. What makes them different are the additives. If the gasoline at a mom-and-pop gas station is dirt-cheap, it's because it has no additives (aka buyer beware).","replyToPid":363602}
发表于 2020-4-27 07:22:12 来自手机 | 显示全部楼层
612787 发表于 2020-04-26 23:07:17 Wow thanks for sharing some knowledge.
","text":"I still do not care about you Bunty!","replyToPid":363589}
 楼主| 发表于 2020-4-27 07:44:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"Hopefully I survive.🤓","replyToPid":0}
发表于 2020-4-27 20:28:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"I live in Minnesota","replyToPid":0}
发表于 2020-4-29 20:45:28 来自手机 | 显示全部楼层
78839 发表于 2020-04-28 13:57:25 Same with gasoline. All gasoline comes from the same refinery, whether Shell, RaceTrac, BP, etc. What makes them different are the additives. If the gasoline at a mom-and-pop gas station is dirt-cheap, it's because it has no additives (aka buyer beware).
","text":"It can also be dirt cheap because mom and pop decided not to f¥©k the public. They learned they can sell more at a lower price and still make more of a profit than the guy down the street trying to screw everyone","replyToPid":364260}
GMT+8, 2026-3-22 02:09 , Processed in 0.086871 second(s), 25 queries .
