查看: 221|回复: 7
Speedco, North Las Vegas,NV
 楼主| 发表于 2020-4-25 03:49:47 来自手机 | 显示全部楼层 |阅读模式
{"text":"Oil change and lube tuck and trailer 424.00$\nnever go back again or do and service with them.\nthey charge you over than 70$ from any place.\neven TA PM oil change not more then 320$.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-4-25 08:59:07 来自手机 | 显示全部楼层
335766 发表于 2020-04-24 21:28:44 You’re ripping yourself off pal lol i go to a local shop and its 320$ oil+filters+lube and yes its Donaldson filters and mobil1 conventional
","text":"cheapest isn't always what's best.","replyToPid":362631}
发表于 2020-4-25 04:01:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"So much for being an informed consumer.","replyToPid":0}
发表于 2020-4-25 05:28:44 来自手机 | 显示全部楼层
953185 发表于 2020-04-24 20:21:43 what exactly are you getting? gotta compare apples with apples.\n\nI change my own oil, it's $200 for the oil, $200 for oil filter, fuel filter, and oil water separator filter, so it's roughly $500 every change for me.
","text":"You’re ripping yourself off pal lol i go to a local shop and its 320$ oil+filters+lube and yes its Donaldson filters and mobil1 conventional ","replyToPid":362598}
发表于 2020-4-25 04:31:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"what happens in Vegas, stays in.... your memories 😂","replyToPid":0}
发表于 2020-4-25 04:21:43 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"what exactly are you getting? gotta compare apples with apples.\n\nI change my own oil, it's $200 for the oil, $200 for oil filter, fuel filter, and oil water separator filter, so it's roughly $500 every change for me."}
 楼主| 发表于 2020-4-27 10:14:02 来自手机 | 显示全部楼层
","text":"it's depends on truck model and engine.\nI have 2010 international Cummins","replyToPid":362598}
 楼主| 发表于 2020-4-27 10:15:10 来自手机 | 显示全部楼层
","text":"I use fleet garud filters","replyToPid":362631}
GMT+8, 2026-3-22 02:09 , Processed in 0.159444 second(s), 24 queries .
