查看: 290|回复: 6
Truck parking in Ranlo/Gastonia, NC?
 楼主| 发表于 2020-4-25 00:51:05 来自手机 | 显示全部楼层 |阅读模式
{"text":"Can anyone recommend anything that's NOT the Loves on I-85? That place is always packed. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-4-25 03:07:07 来自手机 | 显示全部楼层
{"replyTo":"","text":"Try exit 21. Half the stores are shutdown. Lots of parking and restaurants. They generally aren't harassing the trucks these days. Just don't make a mess.","replyToPid":0}
发表于 2020-4-25 17:22:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"There's a spot exit 21..Big Diesel..store your truck there too..also walmart there go to back of lot.","replyToPid":0}
禁止发言
发表于 2020-4-25 01:13:28 来自手机 | 显示全部楼层
发表于 2020-4-25 01:21:17 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"There is one off exit #14 across from Filters Master, I believe they charge for parking unless you pump some gas"}
发表于 2020-4-25 06:19:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"There is a small truck stop off exit 14. Not a huge lot, but every time I’ve been by there they usually have a few spots open...even in the middle of the night","replyToPid":0}
 楼主| 发表于 2020-4-29 08:12:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"Sounds like i need to check out exit 21. thank you guys","replyToPid":0}
GMT+8, 2026-4-15 10:27 , Processed in 0.113661 second(s), 25 queries .
