查看: 138|回复: 3
Announcement: App Crash Issue
 楼主| 发表于 2020-4-24 20:05:43 来自手机 | 显示全部楼层 |阅读模式
{"text":"To all our Trucker Path users,\n\nAn error with Google Maps is causing some Trucker Path and Truckloads users to experience app crashes. We’re aware of this issue and are working with the Google Engineering team to fix it urgently. \n\nUPDATE: April 25, 2020 \nThe root issue has been completely resolved for iPhone users. However, some Android users may still be seeing some issues. \n\nSuggestion 1: \nFor Android users, you will need to update to the latest version 4.0.3 for Trucker Path or version 1.50.7 for Truckloads that contains the patch to the issue. \n\nSuggestion 2:\nIf updating the app doesn’t work, you will need to clear the cache and data to remedy the problem.\nStep 1) Go to the Settings of your phone\nStep 2) Select App from your Settings\nStep 3) Select Trucker Path or Truckloads App\nStep 4) Clear the Cache and Data within the App Storage\nStep 5) Restart Trucker Path and log back in\n\nSuggestion 3: \nIf the previous suggestions don’t resolve the issue, please delete and reinstall the app. Completing these steps should fix any problems with crashes. You can also refer to this statement from Google tracking the latest technical updates.\n\nhttps://issuetracker.google.com/issues/154855417\n","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":810.0,\"name\":\"\",\"url\":\"\",\"width\":750.0}]","canComment":true,"externalShare":false}
发表于 2020-4-24 21:26:45 来自手机
{"replyTo":"","text":"Maybe if you’re app didn’t **** you wouldn’t have that problem!","replyToPid":0}
支持 3 反对 1
发表于 2020-4-25 05:21:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Maybe if you’re app didn’t sück you wouldn’t have that problem ","replyToPid":0}
发表于 2020-4-25 01:01:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"Oh sure....blame it on google maps lmao....","replyToPid":0}
GMT+8, 2026-2-5 19:48 , Processed in 0.058428 second(s), 24 queries .
