查看: 270|回复: 23
I just saved a bunch of money
 楼主| 发表于 2020-4-24 02:21:14 来自手机 | 显示全部楼层 |阅读模式
{"text":"on truck insurance by switching to red fuel😂😂","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-4-24 03:04:36 来自手机 | 显示全部楼层
953185 发表于 2020-04-23 18:49:24 that's how you f your injectors and realized gain/loss will be net negative.\n\nyou also pollute more, and and it's like smoking, realized effects will be net negative.
","text":"You need a Debbie Downer trombone at the end of your comments ","replyToPid":362208}
回复 支持 11 反对 1
发表于 2020-4-24 03:14:41 来自手机 | 显示全部楼层
","text":"I have a friend who hauls fuel from the refinery. Red fuel is simply regular diesel with dye. No difference. Yes there used to be a different grade, no there isn’t now. ","replyToPid":362208}
回复 支持 9 反对 1
发表于 2020-4-24 02:49:24 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"that's how you f your injectors and realized gain/loss will be net negative.\n\nyou also pollute more, and and it's like smoking, realized effects will be net negative."}
回复 支持 2 反对 7
发表于 2020-4-24 06:28:51 来自手机 | 显示全部楼层
","text":"bullscheitzenheimer.  red dye is to identify tax exempt fuel. that's it, same diesel  as taxed. tax evasion if one gets caught.","replyToPid":362208}
回复 支持 6 反对 1
发表于 2020-4-24 05:19:17 来自手机 | 显示全部楼层
953185 发表于 2020-04-23 21:01:17 Your source of information is your friend who hauls fuel. Not the scientist who monitors and test the fuel quality...cool. I'll throw that comment in the trash where it belongs. I'm hauling dove soap, I'm now a soap expert.
","text":"look you just proved your asscumoneme","replyToPid":362222}
回复 支持 7 反对 0
发表于 2020-4-24 09:41:17 来自手机 | 显示全部楼层
953185 发表于 2020-04-24 00:12:08 so when I fuel my sports car and push that 91 octane, that's all the same stuff because it comes out that same hose...should just use 87?\n\n😂😂😂😂😂😂😂😂👌👌👌🤧. Conservatives, stable geniuses, all of them.
","text":"Little pissant still here spewing your stupidity! Go live in North Korea you would love it.","replyToPid":362263}
发表于 2020-4-24 05:01:17 来自手机 | 显示全部楼层
{"replyToPid":362211,"replyTo":"
670777 发表于 2020-04-23 19:14:41 I have a friend who hauls fuel from the refinery. Red fuel is simply regular diesel with dye. No difference. Yes there used to be a different grade, no there isn’t now.
","text":"Your source of information is your friend who hauls fuel. Not the scientist who monitors and test the fuel quality...cool. I'll throw that comment in the trash where it belongs. I'm hauling dove soap, I'm now a soap expert."}
回复 支持 2 反对 3
发表于 2020-4-25 03:17:07 来自手机 | 显示全部楼层
479278 发表于 2020-04-24 18:13:38 you've never had your tanks dipped at a scale?
","text":"He thought they were doing a free cetane rating test.","replyToPid":362551}
发表于 2020-4-24 14:54:36 来自手机 | 显示全部楼层
953185 发表于 2020-04-24 05:59:25 uh...no. Same reason they use a green hose verses a black one, the color is for you to be able to distinguish the difference between the fuel because other than the dye, you can't see the chemical composition.\n\nNo one is opening your tank caps and che king your fuel to make sure you're evading fuel tax. They have a glimpse.based on your IFTA report.
","text":"You’re such a tard. As my Canadian friend told you it’s the same fuel. I run red diesel in my F-250 sometimes.. zero difference in fuel mileage/power over green diesel. I burn red diesel in my reefer unit every chance I can as well. As for IFTA reporting.. no one is recording red diesel going in their tanks.. you gotta make up hand written receipts instead. ","replyToPid":362354}
发表于 2020-4-24 04:57:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"cusemea is special needs 😆 ","replyToPid":0}
发表于 2020-4-24 04:16:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’ve been thinking the same thing.. I can get farm fuel for $1.39/gallon right now around home.","replyToPid":0}
发表于 2020-4-24 04:31:17 来自手机 | 显示全部楼层
","text":"Kinda like when you smoke pole....but different.","replyToPid":362208}
发表于 2020-4-24 05:26:12 来自手机 | 显示全部楼层
","text":"As in my friend sees where the fuel is dispensed and where the dye gets added. On a side note you’re ex wife must be so glad she’s just that. ","replyToPid":362222}
GMT+8, 2026-2-12 00:44 , Processed in 0.073363 second(s), 24 queries .
