查看: 403|回复: 12
180 lbs overweight on tandems going to California.
 楼主| 发表于 2020-4-22 04:40:01 来自手机 | 显示全部楼层 |阅读模式
{"text":"How bad will they ream me for so little? yes I'm at the 40 mark","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
 楼主| 发表于 2020-4-23 13:31:50 来自手机 | 显示全部楼层
946172 发表于 2020-04-22 21:55:05 let us know how it goes for you. Hammerdown!!
","text":"nothing, they let me roll through","replyToPid":361920}
发表于 2020-4-22 05:09:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"yeah you shouldn't have a problem. even if you moved the tandem one more hole they won't say anything either","replyToPid":0}
发表于 2020-4-22 04:44:18 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"you can be 1 percent over"}
发表于 2020-4-23 05:55:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"let us know how it goes for you. Hammerdown!!","replyToPid":0}
发表于 2020-4-23 06:13:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"you're rolling the dice...I was doing 70 down the hill in Coachella and a cop drove by me and flashed his lights, I slowed down and he left me alone. Not everyday you win the lottery. That was during the first days of the panic buying.","replyToPid":0}
发表于 2020-4-22 05:51:41 来自手机 | 显示全部楼层
336899 发表于 2020-04-21 21:10:25 Slide the fifth wheel? Every notch is a few hundred pounds.
","text":"That does nothing for your trailer. That simply moves the weight from drives to steer axle. ","replyToPid":361271}
发表于 2020-4-22 05:10:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"Slide the fifth wheel? Every notch is a few hundred pounds.","replyToPid":0}
发表于 2020-4-22 06:59:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"Is there a weight exemption with the HOS exemption on critical loads?","replyToPid":0}
发表于 2020-4-22 07:38:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"I hope you get a cop having a good day if you get pulled in.","replyToPid":0}
发表于 2020-4-23 04:07:06 来自手机 | 显示全部楼层
{"replyTo":"","text":"I would go one more hole.","replyToPid":0}
GMT+8, 2026-4-18 00:51 , Processed in 0.133555 second(s), 24 queries .
