查看: 53|回复: 0
2016 Peterbilt 579
 楼主| 发表于 2020-4-22 03:03:17 来自手机 | 显示全部楼层 |阅读模式
mileageV2:
{"text":"When it comes to used, commercial, fleet, semi-trucks for sale, look no further than this amazing set of big rigs. \n\nThese well-equipped sleeper trucks are reasonably priced and ready to work, and have been fleet maintained.\n\nAll trucks in this package come with spacious eighty inch double bunk, carpeted, sleeper berths featuring plenty of storage, and, for a limited time, are available in the following exterior colors while supplies last:\n\n|Light Continental | Sovereign Blue | Black |\n\nMiles range from the low to upper 300,000?s.\n\nMost of the trucks in this package are equipped with Collision Mitigation which is important to a lot of fleets these days. \n\nThe engines are all Cummins ISX15 2013 EPA 450 HP @ 1800 RPM?s with engine brake. \n\nThe transmissions are all automated Eaton Fuller FAOM15810S-EC3 10 Speeds.\n\nA dependable 2.64 Gear Ratio designed to work well with automated transmissions is included;\n\nDual air ride cloth high-back captain?s chairs;\n\nPower heated mirrors, power door locks and power windows;\n\nTilt Telescopic Steering;\n\n8 Black gauges;\n\n3 Position Engine Brake; \n\nCruise; \n\n| AM|FM|CD|MP3|Bluetooth Stereo System |\n\nAir conditioning | Power Steering | Traction Control| Interaxle Differential Lock| Kingpin Release | 5th Wheel Slide. \n\nAll switches for the above are on the dash in easy reach of the driver; \n\nChrome backed breakaway mirrors; \n\nCurbside drop down blind spot mirrors; \n\nBody color composite three piece bumpers;\n\nPeterbilt Flex Air Suspension; \n\n36? Air Slide 5th wheel; \n\n2 Back of Cab Lamps;\n\nComposite Quarter Fenders;\n\nYour choice of either a 234? or 236? wheelbase depending on the truck you pick.\n\nDual 100 gallon aluminum fuel tanks with two Arctic Fox fuel heaters;\n\nAll units come with eight new rear virgin tires and 50% or better virgin steers on ten aluminum wheels.\n\nNew Rush Mud Flaps.\n\nAttractive finance and lease purchase options available on approved credit.\n\nCall us today to arrange your choice of in-person or virtual showing of these amazing trucks while supplies last","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":480.0,\"name\":\"\",\"url\":\"\",\"width\":640.0},{\"description\":\"\",\"height\":525.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":525.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":525.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":525.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":525.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":525.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":525.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":525.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":525.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":525.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":525.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":525.0,\"name\":\"\",\"url\":\"\",\"width\":700.0},{\"description\":\"\",\"height\":525.0,\"name\":\"\",\"url\":\"\",\"width\":700.0}]","canComment":null,"externalShare":false}
GMT+8, 2026-4-3 10:15 , Processed in 0.066771 second(s), 25 queries .
