查看: 41|回复: 0
Freightliner
 楼主| 发表于 2020-4-22 02:48:59 来自手机 | 显示全部楼层 |阅读模式
VIN: 1FUJGLDR8CSBF7477
Hide Access Link: https://prd-forum-api.truckerpath.com/v6/direct_link/?actionCode=AccessTruckAndJobAction&pk=fb813f1719e126c05&token=f4ed1dd6daabe7bf3ca94313884ba126
mileageV2: 571283
horsePowerV2: 455
engineManufacturerV2: Detroit
engineTypeV2: DD15
transmissionV2: Eaton Fuller
transmissionTypeV2: FRO15210C
colorV2: White
wheelbaseV2: 240
zipcodeV2: 80022
cityV2: Commerce City
stateV2: CO
condV2: Used Heavy Duty
emailV2: rushcare@rushenterprises.com
makemodelV2: Freightliner Cascadia
phonenoV2: 2107962462
priceV2: 1
stocknoV2: 981453
latitudeV2: 39.86
longitudeV2: -104.86
modelyearV2: 2012
exhaustTypeV2: Single Vertical
LucrativId: 3169035
LocationId: 3116791
{"text":"2012 Freightliner PX125064ST CA125SLP Cascadia 60\" MR Single-Bunk Sleeper Truck, Detroit 14.8L DD15 @ 455 H.P., Engine Brake, Eaton-Fuller FRO-15210C 10-Speed O/D Transmission, 3.55 Ratio, Air-Liner Suspension, 240\" W.B., Aluminum Front Wheels, Steel Rear Wheels, 295/75R-25.5 Lo-Pro Tires, 52K G.V.W.R., Meritor MFS-12-143A FF1 Single (12K) Front-Axle, Meritor MT-40-14X R-SRS (40K) Rear-Axle, Holland Air-Slide 5th Wheel, Cab Air-Ride Suspension, Single Vertical Exhaust, Dual Aluminum 120 Gallon Fuel Tanks, D.E.F. Equipped, Merritt Aluminum Storage Box, P/S, A/C, C/C, Tilt-Telescoping Steering Column, Dual Power Windows, Dual 4-Way Power Mirrors, Mirror Heat, Fleet Maintained, Fresh D.O.T. Inspection, P.M. Service Performed, D.P.F. Cleaned, Warranty Available, Financing Options O.A.C., 571,283 Miles!\r\n\r\nWe also have a deep inventory of used flat-beds, delivery vans, tow trucks, service/utility trucks, dump trucks, water trucks, cab & chassis trucks. If we don't have it, we can find it. Come check out our world class service facility. We can expertly service most truck & commercial vehicles with our factory trained service technicians. We are the largest work truck center in Colorado.","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":100.0,\"name\":\"\",\"url\":\"\",\"width\":150.0}]","canComment":null,"externalShare":false}
GMT+8, 2026-4-3 10:38 , Processed in 0.057381 second(s), 25 queries .
