查看: 41|回复: 0
Peterbilt
 楼主| 发表于 2020-4-22 02:47:56 来自手机 | 显示全部楼层 |阅读模式
VIN: 1XPCP4EX4GD337925
Hide Access Link: https://prd-forum-api.truckerpath.com/v6/direct_link/?actionCode=AccessTruckAndJobAction&pk=6419f0a41719e11748c&token=1e931fc974ccf003a93eb8ef89bb0e77
mileageV2: 316368
horsePowerV2: 525
engineManufacturerV2: Cummins
engineTypeV2: ISX-15
transmissionV2: Fuller
transmissionTypeV2: RTLO18918B
colorV2: White
wheelbaseV2: 260
zipcodeV2: 80631
cityV2: Greeley
stateV2: CO
condV2: Used Heavy Duty
emailV2: rushcare@rushenterprises.com
makemodelV2: Peterbilt 567
phonenoV2: 2107962462
priceV2: 1
stocknoV2: 623130
latitudeV2: 40.42
longitudeV2: -104.74
modelyearV2: 2016
exhaustTypeV2: Dual Vertical
LucrativId: 3168949
LocationId: 3116792
{"text":"2016 Peterbilt 567 44\" LR Sleeper Truck, Cummins 14.9L ISX-15 @ 525 H.P., Engine Brake, Fuller RTLO-18918B 18-Speed O/D Transmission, 3.91 Ratio, Air-Trac Suspension, 260\" W.B., 74,100# G.V.W.R., Meritor MFS-14 (14,600#) Front-Axle, Dana-Spicer D46-170 (46K) Rear-Axle, Watson-Chalin 13,500# Lift-Axle, All Aluminum Wheels, 11R-22.5 Tires, WET-KIT, Holland Air-Slide 5th Wheel, Cab Air-Ride Suspension, D.E.F. Equipped, Dual Aluminum 80 Gallon Fuel Tanks, Dual Vertical Exhaust, Stainless Steel Sun Visor, P/S, A/C, C/C, Tilt-Telescoping Steering Column, Power Mirrors, PDL, Power Windows, \"0\" Miles on Engine O/H, 2yr/200K Cummins N.O.W. Warranty, Fresh D.O.T. Inspection, P.M. Service Performed, D.P.F. Cleaned, Financing Options O.A.C., 316,368 Miles!\r\n\r\nWe also have a deep inventory of used flat-beds, delivery vans, tow trucks, service/utility trucks, dump trucks, water trucks, cab & chassis trucks. If we don't have it, we can find it. Come check out our world class service facility. We can expertly service most truck & commercial vehicles with our factory trained service technicians. We are the largest work truck center in Colorado.","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":760.0,\"name\":\"\",\"url\":\"\",\"width\":944.0}]","canComment":null,"externalShare":false}
GMT+8, 2026-4-3 10:38 , Processed in 0.062532 second(s), 25 queries .
