查看: 382|回复: 10
Do I have to be on sleeper berth for 10 consecutive hours?
 楼主| 发表于 2019-6-4 23:34:47 来自手机 | 显示全部楼层 |阅读模式
{"text":"Or can that be mixed with some off duty time?  ","videos":"[]","link":"{}","pics":"[]","canComment":true}
发表于 2019-6-5 00:25:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"from what I know Sleeper Berth and off-duty time can be mixed as long as it's 10 consecutive hours. when I park for the day I'll put it on one and I'll just leave it there.","replyToPid":0}
发表于 2019-6-5 21:31:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"I go full off duty  no sleeper if caught in cab or out of truck it's a violation when in Berth. I seen it with my own eyes in Abingdon VA at the rest area/ morning ambush site. Virginia DOT gave Driver log Violation and out of service 10 hours for getting out of the truck to go into the Rest area. I have been DOT and nothing said about it. But SLEEPER BERTH MEANS SLEEPER BERTH","replyToPid":0}
发表于 2019-6-5 10:53:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you are in sleeper log sleeper...simple","replyToPid":0}
发表于 2019-6-5 18:19:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"if you're out yes but you can be off duty I do it all the time","replyToPid":0}
发表于 2019-6-5 21:30:53 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"If you split log you have to be in the sleeper berth if I remember probably, otherwise you can do either/or"}
发表于 2019-6-5 22:01:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you want to do a split, you have to start with a full 10 hr in the sleeper, then the 8 in the sleeper and the 2 in the sleeper. otherwise you can mix off and sleeper no problem.","replyToPid":0}
发表于 2019-6-5 22:02:59 来自手机 | 显示全部楼层
186358 发表于 2019-06-05 13:31:38 I go full off duty  no sleeper if caught in cab or out of truck it's a violation when in Berth. I seen it with my own eyes in Abingdon VA at the rest area/ morning ambush site. Virginia DOT gave Driver log Violation and out of service 10 hours for getting out of the truck to go into the Rest area. I have been DOT and nothing said about it. But SLEEPER BERTH MEANS SLEEPER BERTH
","text":"that driver needs to do a dataq","replyToPid":55210}
发表于 2019-6-6 01:23:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Only when your in the sleeper. If you forget,  edit. If you cant edit no big deal. Try to be accurate. It does you good","replyToPid":0}
发表于 2019-6-6 07:27:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"i only use off duty. i dont think i ever used sleeper berth except when i was in training.","replyToPid":0}
GMT+8, 2026-4-18 02:52 , Processed in 0.088167 second(s), 24 queries .
