查看: 41|回复: 0
International
 楼主| 发表于 2020-4-22 02:33:34 来自手机 | 显示全部楼层 |阅读模式
VIN: 3HAMMAAL5CL662972
Hide Access Link: https://prd-forum-api.truckerpath.com/v6/direct_link/?actionCode=AccessTruckAndJobAction&pk=84e09baa1719e044cfa&token=ac54872ab2c224cd5a5bca90833e0bc0
mileageV2: 219875
horsePowerV2: 245
engineManufacturerV2: International
engineTypeV2: MaxxForce DT
transmissionV2: Allison
transmissionTypeV2: 2100 HS
colorV2: White
wheelbaseV2: 254
categoryV2: Other Trucks
zipcodeV2: 80022
cityV2: Commerce City
stateV2: CO
condV2: Used Medium Duty
emailV2: rushcare@rushenterprises.com
makemodelV2: International 4300
phonenoV2: 2107962462
priceV2: 1
stocknoV2: 917162
latitudeV2: 39.86
longitudeV2: -104.86
modelyearV2: 2012
exhaustTypeV2: Horizontal
LucrativId: 3167936
LocationId: 3116791
{"text":"2012 International 4300 Single-Axle Cab & Chassis Truck, IHC 7.6L MF-DT @ 245 H.P., Allison XMSN 2100_HS 5-Speed Automatic O/D Transmission, 5.29 Ratio, Spring-Suspension, 254\" W.B., 186\" Cab-To-Axle, 288\" Back of Cab to End of Frame, 11R-22.5 Tires, Steel Wheels, 25,999# G.V.W.R., NON-CDL, Air-Brakes, Cab Air-Ride Suspension, Dual Aluminum 90 Gallon Fuel Tanks, P/S, A/C, C/C, Tilt-Steering Column, Fresh D.O.T. Inspection, P.M. Service Performed, D.P.F. Cleaned, Fleet Maintained, Warranty Available, Financing Options O.A.C., 219,875 Miles! ","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":300.0,\"name\":\"\",\"url\":\"\",\"width\":300.0}]","canComment":null,"externalShare":false}
GMT+8, 2026-4-3 10:56 , Processed in 0.060936 second(s), 25 queries .
