查看: 195|回复: 9
Camera Speaker Silencing Technique
 楼主| 发表于 2020-4-21 23:27:09 来自手机 | 显示全部楼层 |阅读模式
{"text":"My company finally installed front facing g cameras fleet wide.  This thing is intensely LOUD!  I tried tape, cloth, gray impact foam. \n\nThe camera is solid chassis and has two vent slots, would some kind of synthetic paste work?  \n\nWhat will silence this unne emissary distraction?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-4-22 02:19:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"wire cutters....","replyToPid":0}
回复 支持 5 反对 1
发表于 2020-4-22 02:37:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"It the UN tracking your sound signature for range finding techniques","replyToPid":0}
回复 支持 4 反对 1
发表于 2020-4-22 02:16:44 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"one trick is noise cancellation, some people sleep with the engine on so the refer isn't so loud. So using that logic, if you run your radio on max volume, you shouldn't hear that camera."}
回复 支持 2 反对 3
发表于 2020-4-22 02:50:57 来自手机 | 显示全部楼层
464157 发表于 2020-04-21 18:45:11 all they gotta' do is track my ELD and cell phone.😎🤦‍♂️  seriously, this air raid siren is a bit too much
","text":"That is a UN sounding system to reprogram your biological thought process so you will accept the future wave of personal confinement and motion control.","replyToPid":360114}
 楼主| 发表于 2020-4-24 06:52:21 来自手机 | 显示全部楼层
373529 发表于 2020-04-22 07:37:21 It makes me wonder if they monitor it as much as we think they would ?
","text":"some companies do and some don't.  some dispatchers do and some don't. it's like what some old boomers wear to bed---depends 🤦‍♂️","replyToPid":361611}
发表于 2020-4-22 15:37:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"It makes me wonder if they monitor it as much as we think they would ?","replyToPid":0}
 楼主| 发表于 2020-4-22 02:31:54 来自手机 | 显示全部楼层
945420 发表于 2020-04-21 18:16:44 one trick is noise cancellation, some people sleep with the engine on so the refer isn't so loud. So using that logic, if you run your radio on max volume, you shouldn't hear that camera.
","text":"It's that loud, I can hear it over the engine and radio at full volume","replyToPid":359420}
 楼主| 发表于 2020-4-22 02:45:11 来自手机 | 显示全部楼层
{"replyTo":"","text":"all they gotta' do is track my ELD and cell phone.😎🤦‍♂️  seriously, this air raid siren is a bit too much","replyToPid":0}
 楼主| 发表于 2020-4-22 04:16:30 来自手机 | 显示全部楼层
949826 发表于 2020-04-21 18:50:57 That is a UN sounding system to reprogram your biological thought process so you will accept the future wave of personal confinement and motion control.
","text":"we must obey Zontar. 😳","replyToPid":360336}
GMT+8, 2026-2-14 10:32 , Processed in 0.090619 second(s), 24 queries .
