查看: 233|回复: 7
99 pete 379 cat or 2012 cascadia isx both has 1 million miles?
 楼主| 发表于 2020-4-21 05:02:15 来自手机 | 显示全部楼层 |阅读模式
发表于 2020-4-21 23:14:09 来自手机 | 显示全部楼层
{"replyTo":"","text":"Neither. Turn in your license. And go home.","replyToPid":0}
回复 支持 8 反对 0
 楼主| 发表于 2020-4-21 23:41:37 来自手机 | 显示全部楼层
612134 发表于 2020-04-21 15:14:09 Neither. Turn in your license. And go home.
","text":"🖕🏼","replyToPid":358976}
发表于 2020-4-22 10:59:25 来自手机 | 显示全部楼层
{"replyTo":"","text":"Pete! No brained!!!","replyToPid":0}
发表于 2020-4-21 07:54:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"Well, if you have to ask.....","replyToPid":0}
发表于 2020-4-21 20:28:51 来自手机 | 显示全部楼层
{"replyTo":"","text":"The obvious answer is the Pete. No question. The Frieghliner is junk. Period.  If you're just looking around to lease some where to make a buck, you need to go do some more homework. The fact you are even considering any truck newer than '99, proves that. You want dependability, parts availability, and the freedom that discernment brings.","replyToPid":0}
 楼主| 发表于 2020-4-21 05:56:07 来自手机 | 显示全部楼层
952234 发表于 2020-04-20 21:12:12 pete with cat.. what kind of hømo question is this?
","text":"🖕🏼","replyToPid":358443}
发表于 2020-4-23 21:26:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'd take the PETE","replyToPid":0}
GMT+8, 2026-2-14 09:06 , Processed in 0.074811 second(s), 24 queries .
