查看: 302|回复: 6
How strict are the chicken coops right now on the 40 headed out of Ca to Texas?
 楼主| 发表于 2020-4-20 14:42:42 来自手机 | 显示全部楼层 |阅读模式
发表于 2020-4-20 16:53:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"i had to load at 3 different shipper's to get a full trailer to get out of California","replyToPid":0}
发表于 2020-4-20 18:56:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"I got bypasses through New Mexico,  Arizona and California last week","replyToPid":0}
 楼主| 发表于 2020-4-21 09:47:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"I’m running bobtail in a three axle to Dallas. Out of ca on the 40. I am a class C driver I own the truck however , no tags nor class A license . Gotta pick up a trailer from auction company. Do you think this is to scandalous if I run the scales ? ","replyToPid":0}
发表于 2020-4-21 09:53:52 来自手机 | 显示全部楼层
{"replyTo":"","text":"put a sign not for hire on the door you will be fine","replyToPid":0}
 楼主| 发表于 2020-4-21 12:24:11 来自手机 | 显示全部楼层
952197 发表于 2020-04-21 01:53:52 put a sign not for hire on the door you will be fine
","text":"10-4 driver . Thanks bro! ","replyToPid":358587}
 楼主| 发表于 2020-4-21 12:25:58 来自手机 | 显示全部楼层
","text":"Is it scandalous if I just run by the scales? Or should I roll through pretending I’m all legit","replyToPid":358587}
GMT+8, 2026-4-18 01:36 , Processed in 0.090167 second(s), 24 queries .
