查看: 594|回复: 21
Yesterday 4/18
 楼主| 发表于 2020-4-19 22:36:37 来自手机 | 显示全部楼层 |阅读模式
{"text":"As I was coming in from Oklahoma I notice that my engine breaks quit working. What would be your first go to and look before you decide to have the professionals looks at it 🤔","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-4-19 22:42:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"brake or clutch switch. pull up on them with your foot to find out which one.","replyToPid":0}
发表于 2020-4-19 22:40:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'd check the engine brakes.","replyToPid":0}
 楼主| 发表于 2020-4-20 03:54:44 来自手机
{"replyTo":"","text":"Did I bust your golf ballš 🙊","replyToPid":357976}
支持 0 反对 3
发表于 2020-6-27 06:09:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Throttle or clutch switchas said before i would also check the stage switch on the dash. ","replyToPid":358000}
发表于 2020-4-21 08:54:32 来自手机
945897 发表于 2020-04-21 00:49:54 I do not troll the pickle parks, that is your job.
","text":"No you troll playgrounds looking for young boys.  I saw your post.","replyToPid":358562}
支持 1 反对 1
发表于 2020-4-20 03:16:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"oh is that monawhore","replyToPid":357975}
发表于 2020-4-20 03:17:37 来自手机
{"replyToPid":0,"replyTo":"","text":"check your blinker fluid if that doesn't help then when engine breaking , fuel and a source of oxygen, called an oxidizer, are mixed and exploded in a combustion chamber. The combustion produces hot exhaust which is passed through a nozzle to accelerate the flow and produce thrust. ... There are two main categories of  engine breaking; liquid engine and solid engine,  you gonna have to get on your knees and sûçk dîçk. THAT SHOULD FIX YOUR PROBLEM 😊"}
支持 2 反对 0
发表于 2020-4-20 00:37:21 来自手机 | 显示全部楼层
{"replyTo":"","text":"Maybe switch on clutch or brake pedal just tap them or shut your cruise off ","replyToPid":0}
发表于 2020-4-20 03:14:57 来自手机 | 显示全部楼层
check your fluids
{"replyToPid":357968,"replyTo":"","text":"Yes check your jake brake fluid"}
发表于 2020-4-20 03:58:13 来自手机 | 显示全部楼层
910333 发表于 2020-04-19 19:54:44 Did I bust your golf ballš 🙊
","text":"I think we got off on the wrong lips. Maybe we can startover?","replyToPid":358003}
发表于 2020-4-19 22:41:30 来自手机 | 显示全部楼层
949826 发表于 2020-04-19 14:40:21 I'd check the engine brakes.
","text":"Hahaha","replyToPid":357764}
发表于 2020-4-20 03:07:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"check your fluids","replyToPid":0}
 楼主| 发表于 2020-4-20 03:15:55 来自手机 | 显示全部楼层
952197 发表于 2020-04-19 19:14:57 Yes check your brake jake fluid
","text":"Loser at its best! ","replyToPid":357973}
 楼主| 发表于 2020-4-20 03:52:57 来自手机 | 显示全部楼层
295387 发表于 2020-04-19 16:37:21 Maybe switch on clutch or brake pedal just tap them or shut your cruise off
","text":"I'm going to try this ","replyToPid":357864}
GMT+8, 2026-2-7 05:06 , Processed in 0.137051 second(s), 24 queries .
