查看: 174|回复: 8
Wondering what everyone says now.....
 楼主| 发表于 2020-4-19 11:24:33 来自手机 | 显示全部楼层 |阅读模式
{"text":"Looked up the best cell phone for truckers and didn't find much. Just bored so figured I revist an old post I found. I myself have have a Blu G8 with Cricket. (phones not through them, just plan) I have liked all the Blu phones I've had. Most have failed due to the abuse I put them through. First one I had I actually bent it from side to side just below the side buttons. Never cracked the screen and worked like that for over a yr. What do you all use or say is best.","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1520.0,\"name\":\"\",\"url\":\"\",\"width\":720.0}]","canComment":true,"externalShare":false}
发表于 2020-4-19 23:01:22 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use Verizon and never have a issue and use a iPhone. Straight talk or any other prepaid junk doesn’t get full access too all the towers. Like straight talk from Walmart only uses like half the towers Verizon customers can use. Spend the money for stuff that works. You need the correct tools for the job and don’t limit yourself. ","replyToPid":0}
发表于 2020-4-19 12:10:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"I use visible. runs on Verizon. $40 per month unlimited data plus hotspot. the only dead areas I've found are in the middle of Nevada and Kentucky.","replyToPid":0}
发表于 2020-4-19 11:35:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"i got metros 60 dollar plan. unlimited data talk and text plus 15 gigs of hot spot. juat doesnt really work in wyoming or montana mountains","replyToPid":0}
发表于 2020-4-19 12:38:37 来自手机 | 显示全部楼层
479278 发表于 2020-04-19 04:10:50 I use visible. runs on Verizon. $40 per month unlimited data plus hotspot. the only dead areas I've found are in the middle of Nevada and Kentucky.
","text":"is that unlimited hot spot?","replyToPid":357658}
发表于 2020-4-19 19:46:06 来自手机 | 显示全部楼层
920151 发表于 2020-04-19 04:38:37 is that unlimited hot spot?
","text":"yes I just checked their website. its unlimited hotspot.","replyToPid":357660}
发表于 2020-4-21 03:47:39 来自手机 | 显示全部楼层
You have never been to upper Michigan I take it
{"replyToPid":358425,"replyTo":"
794377 发表于 2020-04-20 19:40:19 You have never been to upper Michigan I take it
","text":"no. traverse City is the furthest I've been up.\n\nat least since cell phones have been around"}
发表于 2020-4-21 04:14:55 来自手机 | 显示全部楼层
779898 发表于 2020-04-19 15:01:22 I use Verizon and never have a issue and use a iPhone. Straight talk or any other prepaid junk doesn’t get full access too all the towers. Like straight talk from Walmart only uses like half the towers Verizon customers can use. Spend the money for stuff that works. You need the correct tools for the job and don’t limit yourself.
","text":"or you can do that.\n\nI was a Verizon customer before they were Verizon back in the bell Atlantic days. when I switched to prepaid the only difference I noticed is more money in my pocket.\n\nthat said, it may be because visible is owed by Verizon. I can't speak about other prepaids.","replyToPid":357786}
 楼主| 发表于 2020-4-21 11:28:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"I'm actually surprised no one commented using Boost or T mobile. Also only saw one say he's using an iPhone. I was hoping for more to tell what phone they were using but the conversation was interesting.","replyToPid":0}
GMT+8, 2026-2-12 02:23 , Processed in 0.109248 second(s), 24 queries .
