查看: 313|回复: 20
PLEASE HELP- OTR DRIVERS WITH SYMPTOMS HAVE NO ACCESS TO MASKS - #covid19, #essentialworkersneedmasks
 楼主| 发表于 2020-4-17 01:38:23 来自手机 | 显示全部楼层 |阅读模式
{"text":"For all the drivers who can’t make it home to make a mask- how are you accessing them ? With limited access to stores and the inventory within - I’m at a loss as to what to do to protect others???\n\nI have clear cut symptoms of the virus and feel compelled to ask for help. \n\nIs there a way to get extra masks to truck stops ??? I’m about to be parked for our 10 hour and would like to get this taken care of ASAP! \n\nAny advice needed\n\n\n\n","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-4-17 03:49:05 来自手机 | 显示全部楼层
{"replyTo":"","text":"Fúckin women....take your dumb àss home and get in a kitchen so a real driver can get in that truck ","replyToPid":0}
回复 支持 6 反对 6
发表于 2020-4-17 01:59:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"You should be tested and shut down. A lot of customers have elderly guards. To make a mask to protect others there are several instructions online how to make a no sew cloth mask using a t shirt looks easiest. I used a pillowcase but I still have medical grade masks left. You should also insert some sort of filter. You can use a coffee filter. I dried some baby wipes to use as a filter. It’s also still cold flu allergy season so it could be anything really. I was getting some serious allergy issues in Washington. Call your dr to screen over the phone for the virus and get a referral for testing. ","replyToPid":0}
回复 支持 4 反对 2
发表于 2020-4-17 05:21:14 来自手机 | 显示全部楼层
{"replyTo":"","text":"Since the end of February, the pollen has made life miserable in the southeast for allergy sufferers. I have even had a mild fever because of it.. All this talk about the Wuhan virus is just like it was in 2009, with the swine flu..It can really put you in a \"funk\" if you let it.. That will cause stress, which if not controlled can possibly knock your immune system as well. Take care..Remember, God is in control.🙏","replyToPid":0}
发表于 2020-4-17 02:27:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"I've been putting my nose in them for years already.","replyToPid":356592}
发表于 2020-4-17 07:08:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"i just hold my breath when i leave the truck. seems to be working","replyToPid":0}
 楼主| 发表于 2020-4-17 01:47:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"Pilot \n\n\n2010 W Clay St, Osceola, IA 50213","replyToPid":0}
发表于 2020-4-17 01:50:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Always with wings!","replyToPid":0}
发表于 2020-4-17 01:56:13 来自手机
{"replyTo":"","text":"Feminine napkins. stick them tight over your face. They work great.","replyToPid":356581}
支持 1 反对 1
19
发表于 2020-4-17 01:42:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"where are you?","replyToPid":0}
发表于 2020-4-17 07:12:38 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"amber, call the amber lamps. But really, if you feel you have it, you need to quarantine for a month. in your truck, at home, or in the grave."}
 楼主| 发表于 2020-4-17 01:54:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Please explain- ","replyToPid":356580}
发表于 2020-4-17 01:58:43 来自手机 | 显示全部楼层
{"replyTo":"","text":"not joking see current post!","replyToPid":356581}
 楼主| 发表于 2020-4-17 02:03:38 来自手机 | 显示全部楼层
950582 发表于 2020-04-16 17:58:43 not joking see current post!
","text":"I believe you!","replyToPid":356584}
 楼主| 发表于 2020-4-17 02:05:45 来自手机 | 显示全部楼层
678033 发表于 2020-04-16 17:59:37 You should be tested and shut down. A lot of customers have elderly guards. To make a mask to protect others there are several instructions online how to make a no sew cloth mask using a t shirt looks easiest. I used a pillowcase but I still have medical grade masks left. You should also insert some sort of filter. You can use a coffee filter. I dried some baby wipes to use as a filter. It’s also still cold flu allergy season so it could be anything really. I was getting some serious allergy issues in Washington. Call your dr to screen over the phone for the virus and get a referral for testing.
","text":"that’s what I think I’m dealing with - exactly what you said from Washington - that’s when it started - always messes with my sinuses for a bit but it seems more intense than normal- \nGlad to hear I’m not alone ! ","replyToPid":356586}
 楼主| 发表于 2020-4-17 02:07:41 来自手机 | 显示全部楼层
","text":"Thanks btw","replyToPid":356584}
GMT+8, 2026-2-14 09:08 , Processed in 0.084585 second(s), 24 queries .
