查看: 255|回复: 3
8 2 split
 楼主| 发表于 2020-4-16 04:48:10 来自手机 | 显示全部楼层 |阅读模式
{"text":"what is the best way or if you can give me a scenario how to apply the 8 2 split","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-4-16 13:51:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"Be careful when splitting your break.\nWith these elogs, some companies have set it up that you must take the 8 first.\nMake sure you put yourself in the sleeper.\nI made the mistake of just putting myself off duty. Elog didn't count it as a split break.\nI was however able to anote it and correct it.\nAfter your 8 you'll see how many hours you gained. Take the additional 2 before hours expire and it'll count as a 10 hour break","replyToPid":0}
发表于 2020-4-16 13:54:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"There's a bit more to it, and a simple way to calculate what you'll have after your 8 in the sleeper.\n\nIf you got a more detailed description of what you are trying to do I'll try to help you.","replyToPid":0}
发表于 2020-4-16 08:48:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"Drive for up to 8 hours, take either 2 or 8 hour break, drive the remaining hours you have and finish taking the rest of your break totaling 10 hours before driving again.","replyToPid":0}
发表于 2020-4-16 08:19:44 来自手机
{"replyToPid":356311,"replyTo":"
945897 发表于 2020-04-15 20:53:54 This comment has been deleted
","text":"seems quite logical"}
支持 1 反对 0
GMT+8, 2026-4-16 20:48 , Processed in 0.108992 second(s), 24 queries .
