查看: 222|回复: 4
CB RADIO SHOPS?
 楼主| 发表于 2020-4-15 23:06:09 来自手机 | 显示全部楼层 |阅读模式
{"text":"Are there any CB radio shops along I-80 & 76 between Omaha and Denver?\nI want buy a whole setup. The radio, antenna, cable and Peterbilt mount (the one that bolts on in place of that downward facing mirror above the passenger's door).\n\nI was planning on going to Walcott Radio, but I didn't have  time yesterday. Now that I'm headed west, it could be weeks before I'm passing through Walcott again, so I'm wondering where else I can go.\n\nIf you can help, thanks!","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-4-16 02:24:07 来自手机
{"replyTo":"","text":"I'll tell you in exchange for your social security number","replyToPid":0}
支持 1 反对 3
 楼主| 发表于 2020-4-16 02:32:52 来自手机
{"replyTo":"","text":"Wow, thanks! It's 382-59-6872.\n\n\nIt also spells Fùc-kY-ousa, isn't that so cool??!\n🙄🖕🤣","replyToPid":0}
支持 1 反对 1
发表于 2022-11-27 18:46:02 来自手机
{"replyTo":"","text":"Go see the Dîck in the Desert, AKA HARD DRIVE Mark Sherman. Lordsburg, NM.\nAnd listen to Lords of Acid on the way there ","replyToPid":0}
支持 1 反对 0
发表于 2020-4-16 05:06:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Great!","replyToPid":0}
发表于 2020-4-16 08:55:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"Put truckers path on your smartphone and you can find cb shops on any highways/interstates","replyToPid":0}
发表于 2020-4-16 14:00:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"Most are currently closed.","replyToPid":0}
发表于 2022-11-24 22:12:18 来自手机 | 显示全部楼层
112609 发表于 2020-04-16 00:55:15 Put truckers path on your smartphone and you can find cb shops on any highways/interstates
","text":"How do that work?","replyToPid":356364}
GMT+8, 2026-4-18 17:24 , Processed in 0.061532 second(s), 24 queries .
