查看: 54|回复: 5
Mechanic
 楼主| 发表于 2020-4-15 17:10:23 来自手机 | 显示全部楼层 |阅读模式
{"text":"Anyone knows any good personal diesel mechanics in Houston Tx \nFreightliner 2016 ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-4-16 14:22:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"TX (Houston) Jaime's Truck Repair\n(832)453-5264\nCan't remember his rate.. I think 70$ hour. \nGood mechanic, knows his stuff. Don't get on the subject of politics with him.","replyToPid":0}
发表于 2020-4-16 14:23:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"What broke?","replyToPid":0}
 楼主| 发表于 2020-4-16 18:33:15 来自手机 | 显示全部楼层
{"replyTo":"","text":"Nothing just buying a used truck and need a mechanic to look at it ","replyToPid":356438}
 楼主| 发表于 2020-4-16 18:35:56 来自手机 | 显示全部楼层
211886 发表于 2020-04-16 06:22:55 TX (Houston) Jaime's Truck Repair\n(832)453-5264\nCan't remember his rate.. I think 70$ hour. \nGood mechanic, knows his stuff. Don't get on the subject of politics with him.
","text":"Thanks for the info \nJust getting a used truck and need someone to take a look at it ","replyToPid":356437}
发表于 2020-4-16 22:09:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"Have mechanic look at it BEFORE you buy it.\nIf they require a deposit, make sure you get it back if the truck is no good... Get it in writing that you will get it back in the form of cash or check... Shady dealers will keep the deposit and say it can be used on another truck... You don't wanna do that.\n\n- Make sure the truck is less than 500k\n- ECM vs Odometer... Which ever is higher is usually correct.\n- make sure you get a full warranty, usually 5000$ for 4 years, unlimited mileage.\n\nObviously, if this is a private sale none of this matters and you'd be screwing yourself.","replyToPid":0}
GMT+8, 2026-2-5 12:59 , Processed in 0.060135 second(s), 23 queries .
