查看: 247|回复: 14
Recap??
 楼主| 发表于 2020-4-15 12:24:10 来自手机 | 显示全部楼层 |阅读模式
{"text":"Can an experienced driver explain how the recap works? ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-4-15 14:06:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"simple really they grind the old tread off the tire casing they inspected pretty good and then they glue another casing on the top now you have a recap","replyToPid":0}
发表于 2020-4-16 03:23:35 来自手机 | 显示全部楼层
{"replyTo":"","text":"You have an 8 day week, within which to work 70 hours. At midnight of the 8th day, you get the 1st day’s hour back. So basically, if you work 8.5 hours every day with a short shift of about 6 hrs on the 8th day, then you get back back 8.5 hrs at midnight on the 8th day. It’s really all about proper time management. If you work it properly, you can run 7 days a week with No Need for a 34 hr reset. I personally spend about 2-3 months out between homecalls... and I Never do a 34hr reset... it’s all Recap hrs!","replyToPid":0}
发表于 2020-4-15 22:56:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Someone wasn’t paying attention is school.   ","replyToPid":0}
发表于 2020-4-16 03:33:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"google it","replyToPid":0}
发表于 2020-4-15 14:15:51 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"asking this question every hour, juano is a bot."}
发表于 2020-4-15 13:35:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"After 8days you get back your on duty hrs   Ck the e-log hrs of service under 8days it will show the hrs you get back ","replyToPid":0}
发表于 2020-4-15 13:51:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"start driving on monday and work all days tiil next week. the hours you worked last monday you get them back this monday. on duty and drive time go back on your 70. do with them as you wish.","replyToPid":0}
 楼主| 发表于 2020-4-15 21:58:02 来自手机 | 显示全部楼层
815642 发表于 2020-04-15 06:06:18 simple really they grind the old tread off the tire casing they inspected pretty good and then they glue another casing on the top now you have a recap
","text":"🤣 good one","replyToPid":356139}
 楼主| 发表于 2020-4-15 22:00:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Should have made it clear I meant recap on the eld but thanks guys ","replyToPid":0}
GMT+8, 2026-2-14 09:06 , Processed in 0.072319 second(s), 24 queries .
