查看: 112|回复: 7
Recap??
 楼主| 发表于 2020-4-15 12:22:29 来自手机 | 显示全部楼层 |阅读模式
{"text":"Can an experienced driver explain how the recap works? ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-4-15 12:27:31 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"easiest way to think about it is every 7 days, you drop off the oldest day and you get those hours back."}
发表于 2020-4-15 13:07:21 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"yeh, so when the same day of the week comes, the hours you drove that day last week, you get it back on your total hours for your 8 days/70 hours.\n\nso if you drive 8 1/2 hours every single day, you can drive everyday non-stop."}
发表于 2020-4-15 21:15:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"Same way you mama works.........!..............","replyToPid":0}
 楼主| 发表于 2020-4-15 21:55:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks for the help guys!... ","replyToPid":0}
发表于 2020-4-16 07:04:38 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"After a tire passes inspection, you run it through the buffing process, which eliminates the old tread, revealing what you call the “undertread.” The freshly buffed surface is what allows you to RECAP the tire with quality material for uneliable performance."}
发表于 2020-4-17 11:46:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can work 70 hrs over 8 days. Only work 10 hrs in a midnight to midnight 24 period and on the eighth day you recap(recover)(reacquire)(reload) the 10 hrs from day 1 into your 70 hr clock. Imagine an hour glass with 70 pebbles, 10 pebbles fall out everyday, on the 7 day(7day x10hr=70clock) you’re empty so you can reset or leave one pebble in the hour glass so you don’t have to and the next day the DOT fairly will sprinkle the first 10 pebbles that fell out back into the top of your hour glass. ","replyToPid":0}
发表于 2020-4-18 06:23:31 来自手机 | 显示全部楼层
{"replyTo":"","text":"call ur recruiter or ask ur safety officer","replyToPid":0}
GMT+8, 2026-2-12 04:15 , Processed in 0.154706 second(s), 24 queries .
