查看: 61|回复: 1
no air in primary tank
 楼主| 发表于 2020-4-15 11:07:51 来自手机 | 显示全部楼层 |阅读模式
{"text":"secondary tank is okay. can anyone pin point where to start to look for the problem. or just give me a general idea of how the air system works. thanks.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
 楼主| 发表于 2020-4-17 05:59:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"fixed, no thanks to TP community. Worthless as I knew you'll are. Message me if you have the same problem and I can tell you about my problem for three easy payments of $19.99.","replyToPid":0}
GMT+8, 2026-4-17 14:25 , Processed in 0.072719 second(s), 23 queries .
