查看: 234|回复: 3
HELP!!! what is this problem? How much will the repair cost?
 楼主| 发表于 2020-4-14 09:12:57 来自手机 | 显示全部楼层 |阅读模式
{"text":null,"videos":"[{\"url\":\"http://d2w8udw005hdju.cloudfront.net/video/329044/ios_949543_1586826711490.mp4\"}]","link":"{}","pics":"[{\"description\":\"\",\"height\":345.0,\"name\":\"\",\"url\":\"\",\"width\":200.0}]","canComment":true,"externalShare":false}
发表于 2023-7-29 12:05:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"no.  is not a problem at all.   is normal on volvo truck. that is the engine is releasing the gases for the hot oil in the engine.   OMG.   to be a driver you should have Noles of mechanic.    atlest a little bit.","replyToPid":0}
发表于 2020-4-14 09:22:43 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"first replace crankcase filter.\nfor a temporary fix you can take a 1 inch rubber hose and loop it around from the inlet to the outlet of your crankcase filter then just run a hose from the valve cover down then see if its better.\nif it  still a problem probably going to need a rebuild."}
发表于 2020-4-14 09:17:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"From what I know it's from pressure in the crankcase. Could be a minor fix or could be major. Best to get it checked just to make sure it's nothing major.","replyToPid":0}
GMT+8, 2026-3-21 08:13 , Processed in 0.105783 second(s), 24 queries .
