查看: 450|回复: 26
He has a sidekick named....
 楼主| 发表于 2020-4-13 22:21:49 来自手机 | 显示全部楼层 |阅读模式
{"text":"Art Gallery","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2016.0,\"name\":\"\",\"url\":\"\",\"width\":1134.0}]","canComment":true,"externalShare":false}
发表于 2020-4-13 22:28:58 来自手机 | 显示全部楼层
{"replyTo":"","text":"😂😂😂","replyToPid":0}
发表于 2020-4-14 09:43:01 来自手机
943163 发表于 2020-04-13 22:45:55 You know very little about what you're talking about, so your little l laughing emojis just make you look that more ignorant 😂😂
","text":"I think the same thing every time that silly dipshít comments on something. ","replyToPid":355559}
支持 2 反对 1
发表于 2020-4-14 09:37:59 来自手机 | 显示全部楼层
934316 发表于 2020-04-13 22:41:57 How old is this junk you driving? I thought smart and intelligent dude like you would be driving 2021😂😂
","text":"il take old junk over any emissions garbage new trucks anyday!  just because you couldn't fix a wiper blade yourself!","replyToPid":355557}
 楼主| 发表于 2020-4-13 22:36:50 来自手机
{"replyToPid":355351,"replyTo":"
945946 发表于 2020-04-13 14:34:08 This comment has been deleted
","text":"You see the snow on the ground? I'm in freaking 'cold as fùck Nebraska'"}
支持 2 反对 1
发表于 2020-4-14 12:16:54 来自手机 | 显示全部楼层
8 track, mòròn, because that has everything to do with mpg.....wow.
{"replyToPid":355737,"replyTo":"
943163 发表于 2020-04-14 04:07:54 8 track, mòròn,  because that has everything to do with mpg.....wow.
","text":"Well  MPG didn't help! You are driving a truck that's worth 25K, cheaper than my pickup truck. \n\nAgain, Hey are you serious you driving 28 year old truck ????????? 🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣🤣"}
发表于 2020-4-14 10:11:12 来自手机
945946 发表于 2020-04-14 02:06:01 And I understand now why “Mr Sir has a prolapsed àsshole” 😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂😂🍆🍆🍆🍆🍆🍆🍆🍆🍆🍆🍆🍆🍆🍆🍆🍆🍆🍆🍆🍆🍆🍆🍆🍆🍆🍆😘
","text":"you know nothing about me, keep guessing till you go totally retardd 😂😂😂","replyToPid":355689}
支持 0 反对 2
发表于 2020-4-14 08:03:20 来自手机 | 显示全部楼层
","text":"I see you tried hard for the answer, thank you 😂","replyToPid":355559}
发表于 2020-4-14 04:48:50 来自手机 | 显示全部楼层
","text":"(Well, the southeast is, basically, underwater.) 🤔"}
发表于 2020-4-13 22:34:08 来自手机
{"replyTo":"","text":"I wish I was in the southwest right now!!! Fùck the northeast!","replyToPid":0}
支持 2 反对 0
发表于 2020-4-14 11:13:17 来自手机 | 显示全部楼层
943163 发表于 2020-04-14 02:57:32 1994 379 Pete exude\n90\" bunk, 310\" WB, 3406E pushing 715 HP and 1670 ft lb. to the wheels\n18 speed EF, 3.73 rears.\n375k on rebuild: motor, trans and rears\nFoot to the floor...147 MPH\n\n1998 FLD 120: 515 HP N-14, Super 10, 3.56 rears. Stand up bunk\n\n1998 Frt 120 Classic: 560 HP 12.7 Detroit,  super 10, 3.55 rears. Stand up bunk.\n\n1999 Eagle 9900IX 660 HP 6NZ 18 SPD, 3.33 REARS..Mid roof bunk.\n\nAll have been unframed within the last 400k miles. After I thoroughly inspect a truck that I am interred in, I buy it, take it to my shop and tear out the interior.  \n\nThey get new top of the line seats.  All flooring is ripped out. Everything scrubbed and sanitized, new flooring installed.  Old mattress thrown out and replaced with a top of the line $600 mattress.  All lights interior lights replaced with LED strip lighting.  3000 watt power inverter, microwave, fridge and TV's put in.  Paint is buffed out and usually clear coated.  If not already equipped, a pyrometer is installed.  \n\nI see more NEW junk on the hook than this old shìt that I run lol.  I've been in shops across the country that have had  NEW trucks with the motors on the ground.  I do not need to worry about def, egr or dpf systems nor do I need to worry about ELD's.  My old junk is in top running condition ALWAYS. Oil changed EVERY 9,000 miles...oil samples taken at every 36,000 miles.  \n\nNow I'm sure you are googling half of the stuff that I listed. \n\nNext week I am purchasing another 98 Classic,  gonna get her legal and do a west coast turn and burn....put her through the paces.  Then to my shop for all new interior. The current 3406E cat will be pulled and replaced with a C-16....(yes a 16) Marine Cat that I personally built over the last 4 years....alone the engine is worth about 60 grand, she'll be putting out about 800 HP backed by a EF 15 spd, 1650 ftlbs to the wheels.\n\nSo...you can have your 2021 throw away trucks. As you're sitting in the lot waiting for your POS to Regen,  I'll be rolling out and rolling coal laughing at you....much as I am now.\n\nOk, well, my dirty thirty is up...hasta la vista dòùchè.
","text":"Dàmn son I almost want to drive one of your trucks.","replyToPid":355709}
发表于 2020-4-14 06:41:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"How old is this junk you driving? I thought smart and intelligent dude like you would be driving 2021😂😂","replyToPid":0}
 楼主| 发表于 2020-4-14 06:44:41 来自手机 | 显示全部楼层
{"replyToPid":355557,"replyTo":"
","text":"..."}
 楼主| 发表于 2020-4-14 06:45:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"You know very little about what you're talking about, so your little l laughing emojis just make you look that more ignorant 😂😂","replyToPid":0}
 楼主| 发表于 2020-4-14 08:42:55 来自手机 | 显示全部楼层
934316 发表于 2020-04-14 00:03:20 I see you tried hard for the answer, thank you 😂
","text":"No sense bud....none.","replyToPid":355589}
发表于 2020-4-14 09:37:27 来自手机 | 显示全部楼层
{"replyTo":"","text":"My sidekick is named Corona Cowgirl","replyToPid":0}
GMT+8, 2026-2-12 06:10 , Processed in 0.081361 second(s), 24 queries .
