查看: 119|回复: 4
can you collect welfare of you make less than $75,000 dollars a year?
 楼主| 发表于 2020-4-13 21:14:59 来自手机 | 显示全部楼层 |阅读模式
{"text":"talk radio said if you make more than $75000 dollars a year you don't get a stimulus check","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":2080.0,\"name\":\"\",\"url\":\"\",\"width\":1560.0}]","canComment":true,"externalShare":false}
发表于 2020-4-13 22:19:58 来自手机
{"replyTo":"","text":"You get a smaller check.  But it's NOT a fùckin welfare check.","replyToPid":0}
支持 5 反对 0
发表于 2020-4-13 22:34:38 来自手机
{"replyTo":"","text":"My babies mommas need money. I need crack","replyToPid":0}
支持 2 反对 1
发表于 2020-4-13 22:32:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ya gotta black to get a welfare check.","replyToPid":0}
发表于 2020-4-13 21:21:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"If you make over 75k you have to pay 1,200.","replyToPid":0}
发表于 2020-4-14 12:39:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"You can make up to $75k individually OR $150k per couple and get the full $1,200 per person and $500 per child. It starts going down after that until the cut off of $99k individually OR $198k per couple","replyToPid":0}
发表于 2020-4-13 21:40:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"It sounds like if you filed taxes under $75000 you will get $1200 per person $500 for each child","replyToPid":0}
GMT+8, 2026-2-14 10:32 , Processed in 0.060477 second(s), 24 queries .
