查看: 439|回复: 18
Irritating noise
 楼主| 发表于 2020-4-12 14:08:50 来自手机 | 显示全部楼层 |阅读模式
{"text":"It doesn’t matter what cup we use in the cup holders we always get chirps, rattling or that horrible styrofoam rubbing sound (just as bad as nails down a chalkboard 😫). Any suggestions of a solution? I’ve tried placing a “bed” of paper towels down in there first before placing the cup but it’s just not happening.","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-4-14 09:56:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"Maybe try closing your mouth?","replyToPid":0}
回复 支持 4 反对 1
发表于 2020-4-12 15:00:42 来自手机 | 显示全部楼层
{"replyTo":"","text":"wrap the paper around your cup, the rattling happens where the cup touches the cupholder. I use a metal cup, never rattles.","replyToPid":0}
回复 支持 3 反对 2
发表于 2020-4-12 15:36:02 来自手机 | 显示全部楼层
{"replyTo":"","text":"Get one of those can koozies that you use for aluminum cans.  Use a cup that a koozie will fit around.  Might be easier than always wrapping paper towels around your cup all the time.","replyToPid":0}
发表于 2020-4-12 21:10:03 来自手机 | 显示全部楼层
{"replyTo":"","text":"felt patches around the cups also work really well.","replyToPid":0}
发表于 2020-4-12 23:35:20 来自手机 | 显示全部楼层
{"replyTo":"","text":"Buy ear plugs.","replyToPid":0}
 楼主| 发表于 2020-4-12 15:07:38 来自手机 | 显示全部楼层
945420 发表于 2020-04-12 07:00:42 wrap the paper around your cup, the rattling happens where the cup touches the cupholder. I use a metal cup, never rattles.
","text":"Thank you","replyToPid":355050}
 楼主| 发表于 2020-4-18 15:21:16 来自手机 | 显示全部楼层
945897 发表于 2020-04-17 18:29:34 oh yes. I remember seeing those on Facebook a few years ago. Pëë like a man!  Yes you are right I advise do not attempt to if you guys are rolling through state of Indiana. They’re the worst.
","text":"I-20 LA into TX & anywhere in MI ...AWFUL HIGHWAYS","replyToPid":356988}
 楼主| 发表于 2020-4-17 23:08:38 来自手机 | 显示全部楼层
945897 发表于 2020-04-15 14:54:13 I’m sure she could pull that off as long as her husband was the one driving.
","text":"Hahaha! Actually I have a “Go Girl” that I use when needing to go \nIt’s still tricky to use when my boyfriend is driving depending on what highway we’re on. ","replyToPid":356197}
发表于 2020-4-14 07:00:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"Wait you pee into cup too? I am lost lol","replyToPid":0}
发表于 2020-4-13 13:33:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"I usually line mine with gorilla tape.","replyToPid":0}
发表于 2020-4-12 15:31:34 来自手机 | 显示全部楼层
","text":"Are you sure rattling happens when two objects touch each other?","replyToPid":355050}
发表于 2020-4-12 17:28:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"Fold a small paper towel up, may hafta cut in half. Lay it in the bottom of the cup holders","replyToPid":0}
发表于 2020-4-12 20:09:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have a regular coffee cup in my holder then I put it inside it to hold the cup ","replyToPid":0}
发表于 2020-4-13 00:19:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"The hood could make that same sound lol if the cup is surrounded by a \"bumper\" you might just need to add a sock or two under the hood","replyToPid":0}
GMT+8, 2026-4-16 18:41 , Processed in 0.126271 second(s), 24 queries .
