查看: 277|回复: 21
Engine
 楼主| 发表于 2020-4-11 14:08:46 来自手机 | 显示全部楼层 |阅读模式
{"text":"Somebody tell me something about these paccar MX 13 engines 579 peterbilt 2016 455HP  400k mi \nAre they any good?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-4-11 15:40:41 来自手机 | 显示全部楼层
945420 发表于 2020-04-11 07:00:49 probably not, there is a reason mega carriers get rid of trucks before 500k. probably needs an overhaul after another 100k. plan for a $30k overhaul or you're rolling the dice.
","text":"They get rid of them before 500k so there is something left of value to sell.\nI see you are still making stuff up as you go troll.","replyToPid":354761}
发表于 2020-4-12 07:01:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"every engine manufactured after 2006 is a \"B100\", none will make 1 millions miles","replyToPid":0}
发表于 2020-4-12 03:21:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"dont even think about buying a truck with a paccar engine","replyToPid":0}
发表于 2020-4-11 19:02:21 来自手机 | 显示全部楼层
737135 发表于 2020-04-11 08:46:24 PAC car engines are touchy freely they have a lot of sensors on them but they are good engines. Better then the Cummins there you go
","text":"Better the Cummins? LMAO ","replyToPid":354772}
发表于 2020-4-11 16:46:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"PAC car engines are touchy freely they have a lot of sensors on them but they are good engines. Better then the Cummins there you go ","replyToPid":0}
发表于 2020-4-11 22:37:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"They don't get rid of them after 500k because they probably need an overhaul.  They get rid of them because they still have value, they get huge savings when trading in X amount of trucks for new and also tax purposes (rolling stock).  You're taking a gamble on whatever you buy.  If you're interested in a particular truck...run the VIN and find out it's maintainence history.  If possible,  have a oil sample done, that will tell you alot from the results.  If it has massive blòw-by...do NOT buy it.  And whatever you do...do not listen to that zTXLH wackò.","replyToPid":0}
发表于 2020-4-11 16:44:34 来自手机 | 显示全部楼层
947763 发表于 2020-04-11 07:35:54 Thank you i didn’t purchase it yet need information on it but I’m hearing the dpf system could go out or something
","text":"I'm not saying to not purchase it, just realize it will need money spent for maintenance, $30-50k. DEF system isnt bad if you replace the filters.","replyToPid":354763}
发表于 2020-4-11 16:38:20 来自手机 | 显示全部楼层
211886 发表于 2020-04-11 07:40:41 They get rid of them before 500k so there is something left of value to sell.\nI see you are still making stuff up as you go troll.
","text":"don't listen to these company drivers, the big maintenance is around 500k, that's why companies dump the truck.","replyToPid":354765}
发表于 2020-4-11 15:00:49 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"probably not, there is a reason mega carriers get rid of trucks before 500k. probably needs an overhaul after another 100k. plan for a $30k overhaul or you're rolling the dice."}
发表于 2020-4-12 09:19:28 来自手机 | 显示全部楼层
{"replyTo":"","text":"the motors are good the only problem is with those miles like with Cummins you are going to start having emission system problems I have a 2015 389 Pete with the paccar in it with almost 600,000 I've replaced three sensors 1 filter I just did the turbo and now my EGR is acting up will be replacing that soon","replyToPid":0}
 楼主| 发表于 2020-4-11 15:35:54 来自手机 | 显示全部楼层
","text":"Thank you i didn’t purchase it yet need information on it but I’m hearing the dpf system could go out or something ","replyToPid":354761}
发表于 2020-4-11 15:54:46 来自手机 | 显示全部楼层
{"replyTo":"","text":"And since you have a problem with what you consider \"fake news\", I'll give you some factual news... Your mother should have been slapped for not swallowing you.","replyToPid":0}
发表于 2020-4-11 20:22:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"Junk from the factory","replyToPid":0}
GMT+8, 2026-2-5 11:23 , Processed in 0.097383 second(s), 24 queries .
