查看: 491|回复: 48
Question for Rookies out there...
 楼主| 发表于 2020-4-11 09:16:17 来自手机 | 显示全部楼层 |阅读模式
{"text":"You're pulling an empty trlr on an icy highway, all of sudden you lose control and start skidding. You see a jackknife combo heading toward a ditch.\n\nI know Steering or Service brake won't help but, Do you guys think holding onto TRAILER BRAKE will save your day?? ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-4-11 10:10:23 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"Stick your head out the window yelling clear the way and just run along side it drag your feet!"}
回复 支持 7 反对 1
发表于 2020-4-11 10:13:10 来自手机 | 显示全部楼层
934316 发表于 2020-04-11 02:12:17 you could never be serious mr troll #1
","text":"How do you think the bandit made it down mont eagle backwards with no air brakes?","replyToPid":354692}
回复 支持 6 反对 1
发表于 2020-4-11 13:53:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"Lemme put my 25 cents in (inflation) and help you guys out...\n1. Wtf are you doing on an icy hill with an empty trailer in the first place (smartphone told you weather ahead of time).\n2. Engine brake  has 3 settings for a reason (believe it or not, it's not to sing the song of our people in 3 different tempo's), use setting 1 or 2 depending on hill grade.\n3. There's always the option of \"riding it out\"\n4. There's always the option of a controlled wreck. (contrary to popular belief, this is not only do-able, it's been done many a time by them really old school drivers)\n5. Trailer brake, (correct name is \"trolley brake\"), is the wrong way to go... Reason being... If said rookie has no experience with it, chances are it will go something like this...\n      Rookie pulls on trolley brake, inexperience causes him to pull to hard, looks in mirror just as the locked trailer brakes cause the trailer to begin a jack knife. Said rookie releases trolley brake (again, inexperience kicks in) and instead of \"pausing\" for a moment to allow trailer to unlock, which would more than likely cause it to return to its correct position behind the tractor, rookie instead, with white knuckled grip on steering wheel, slams the brake pedal to the floor, which in turn causes an un-epic crash that no one notices, because everyone with half a brain saw the weather and parked their truck.\n\nGramma nazis need not respond.","replyToPid":0}
回复 支持 4 反对 1
发表于 2020-4-11 10:07:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"Use your engine break!","replyToPid":0}
回复 支持 3 反对 2
发表于 2020-4-11 09:44:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"turn the wheel hard over and hit the gas","replyToPid":0}
回复 支持 3 反对 2
发表于 2020-4-11 10:21:24 来自手机 | 显示全部楼层
934316 发表于 2020-04-11 02:16:03 I think I lost the bet 😀
","text":"What did bet your millennial virgin àss?","replyToPid":354695}
发表于 2020-4-11 09:22:36 来自手机 | 显示全部楼层
{"replyTo":"","text":"Maybe short bursts , but don't just hold it , trailer brakes will most likely lock up , then your j knifed also ","replyToPid":0}
回复 支持 2 反对 2
发表于 2020-4-11 10:23:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Engine brake can also cause a j knife , just sayin !! Bin Dare Dun Dat !","replyToPid":0}
发表于 2020-4-15 09:56:09 来自手机 | 显示全部楼层
654794 发表于 2020-04-13 22:54:13 Engine Brake will get you jack knife also lol it says in Volvos User Manual never to use engine brake on wet and slippery condition..... 😀
","text":"Not disagreeing with you.\nThe user manual was written by someone who more than likely never drove a truck.\nAnd if they did, it was under ideal conditions.","replyToPid":355560}
 楼主| 发表于 2020-4-13 05:50:29 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"it's just a question nobody put themself in such condition. I just asked because temperatures are rising and you could run into black ice during night.\n\njust go fcuk yourself if you have no proper answer. it doesn't surprise how your stupidd asss can come up with such an intelligent answer"}
 楼主| 发表于 2020-4-11 10:12:17 来自手机 | 显示全部楼层
947584 发表于 2020-04-11 02:10:23 just run along side it drag your feet!
","text":"you could never be serious mr troll #1","replyToPid":354691}
 楼主| 发表于 2020-4-11 10:15:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"I lost a bet then, I told my company driver trailer never moves, its tractor that is dancing.\n\njust stop the trailer and it will stop tractor..may be I was wrong 😁","replyToPid":0}
 楼主| 发表于 2020-4-11 10:16:03 来自手机 | 显示全部楼层
280207 发表于 2020-04-11 01:22:36 Maybe short bursts , but don't just hold it , trailer brakes will most likely lock up , then your j knifed also
","text":"I think I lost the bet 😀","replyToPid":354683}
GMT+8, 2026-2-14 06:07 , Processed in 0.148433 second(s), 24 queries .
