查看: 274|回复: 16
Best buy i made this year No inverter no problem
 楼主| 发表于 2020-4-10 01:22:15 来自手机 | 显示全部楼层 |阅读模式
{"text":null,"videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1124.0,\"name\":\"\",\"url\":\"\",\"width\":750.0}]","canComment":true,"externalShare":false}
发表于 2020-4-11 05:03:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"where does my pp go in?","replyToPid":0}
发表于 2020-4-10 01:42:07 来自手机 | 显示全部楼层
864562 发表于 2020-04-09 17:34:54 just too bad milwaukee hasnt made one yet
","text":"With is it besides a coffee maker?","replyToPid":353961}
 楼主| 发表于 2020-4-10 01:34:54 来自手机 | 显示全部楼层
{"replyTo":"","text":"just too bad milwaukee hasnt made one yet","replyToPid":0}
发表于 2020-4-10 03:22:59 来自手机 | 显示全部楼层
{"replyTo":"","text":"A battery powered coffee maker?","replyToPid":353969}
发表于 2020-4-10 02:12:56 来自手机 | 显示全部楼层
674254 发表于 2020-04-09 17:42:07 With is it besides a coffee maker?
","text":"that's what it is","replyToPid":353963}
发表于 2020-4-10 03:07:49 来自手机 | 显示全部楼层
{"replyTo":"","text":"How are you going to charge the battery?","replyToPid":0}
发表于 2020-4-10 05:11:08 来自手机 | 显示全部楼层
{"replyTo":"","text":"you can’t just plug in a keurig?","replyToPid":0}
 楼主| 发表于 2020-4-10 07:49:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"Keurig machines take a lot of juice to run your inverter would need to be able to handle the wattage a reg coffee machine requires with this u only need to have enough wattage to charge a battery and good to go","replyToPid":0}
 楼主| 发表于 2020-4-10 07:52:56 来自手机 | 显示全部楼层
674254 发表于 2020-04-09 19:22:59 A battery powered coffee maker?
","text":"Yep finally... prob the only one out there","replyToPid":353992}
 楼主| 发表于 2020-4-10 08:01:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"Only downside u need to charge the battery with a separate charging dock both not included and the machine has no power cord so battery only","replyToPid":0}
GMT+8, 2026-2-14 09:16 , Processed in 0.077973 second(s), 24 queries .
