查看: 219|回复: 13
Keurig in the truck
 楼主| 发表于 2020-4-9 20:34:10 来自手机 | 显示全部楼层 |阅读模式
{"text":"Good morning y'all, I went and bought a Keurig mini b30 as someone suggested on here for coffee in the morning. I have a 3000 watt inverter and don't know why, but it seems that I don't have enough power for it. Any advice? Hope everyone has a good day ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-4-10 03:23:37 来自手机 | 显示全部楼层
{"replyTo":"","text":"I would suggest that you could I 250 M and fuse from the inverter to the battery that it will work properly","replyToPid":0}
发表于 2020-4-9 23:51:55 来自手机 | 显示全部楼层
{"replyTo":"","text":"yes bad inverter. according to their website they only pull 1450 watts at startup.","replyToPid":0}
 楼主| 发表于 2020-4-10 10:42:40 来自手机 | 显示全部楼层
{"replyTo":"","text":"I do take it up a bit,  microwave runs fine","replyToPid":0}
发表于 2020-4-10 04:29:21 来自手机 | 显示全部楼层
327523 发表于 2020-04-09 20:28:11 That’s good to hear. I just bought the same one. Haven’t plugged anything into it yet.
","text":"The bluetooth option is really convenient.","replyToPid":354029}
发表于 2020-4-10 00:03:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"A 3,000 watt inverter should be plenty to run a Keurig!! I have a 3,000 watt that runs my microwave, TV, coffee pot and slow cooker.  When using my microwave,  everything else needs to be turned off.  What brand of inverter did you get?","replyToPid":0}
发表于 2020-4-10 04:28:11 来自手机 | 显示全部楼层
943163 发表于 2020-04-09 16:49:54 Should be sufficient. Do you have it wired directly to the batteries? and also using thick enough cables? \n\nI have a PowerDrive 3,000 watt ( sold at most truckstops)  I've had it for 4 years and haven't had any problems with it.
","text":"That’s good to hear. I just bought the same one. Haven’t plugged anything into it yet.","replyToPid":353951}
发表于 2020-4-10 00:49:54 来自手机 | 显示全部楼层
932600 发表于 2020-04-09 16:14:47 Tundra powersine, 3000 watt
","text":"Should be sufficient. Do you have it wired directly to the batteries? and also using thick enough cables? \n\nI have a PowerDrive 3,000 watt ( sold at most truckstops)  I've had it for 4 years and haven't had any problems with it.","replyToPid":353940}
发表于 2020-4-9 21:15:57 来自手机 | 显示全部楼层
{"replyTo":"","text":"Yep has to be direct wired to batteries. If you already have it to batts, then likely a bad inverter ","replyToPid":0}
 楼主| 发表于 2020-4-10 00:14:47 来自手机 | 显示全部楼层
{"replyTo":"","text":"Tundra powersine, 3000 watt","replyToPid":0}
发表于 2020-4-9 21:03:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Unless it’s hard wired to the battery you won’t have enough power.... I had the same problem. My company won’t allow it either so I bought a huge thermos from LLBean and mini crockpots to heat food and coffee. ","replyToPid":0}
 楼主| 发表于 2020-4-9 23:35:32 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thanks y'all, already direct to the batt's, probably a bad inverter. Have a good day, drive safe","replyToPid":0}
 楼主| 发表于 2020-4-10 00:03:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"Thank you, yeah just used my microwave, no issues. 🤔 Still might be bad inv. I just looked at my Keurig, says 1425 watts. I'll figure it out.","replyToPid":0}
GMT+8, 2026-2-12 06:01 , Processed in 0.101952 second(s), 24 queries .
