查看: 296|回复: 14
purple seat
 楼主| 发表于 2020-4-8 07:03:26 来自手机 | 显示全部楼层 |阅读模式
{"text":"Has anyone purchased that Purple Seat pad I see in a lot of truck stops?  What's yur opinion on it?  Is it worth the almost $50 for it? \n\nthx in advance for your review. ","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-4-8 10:18:41 来自手机 | 显示全部楼层
{"replyTo":"","text":"one thing I know is that some people are hard as and some are soft as, you gotta try it yourself for a prolonged period to know if it's for you.","replyToPid":0}
发表于 2020-4-8 10:08:56 来自手机 | 显示全部楼层
{"replyTo":"","text":"Crap ","replyToPid":0}
发表于 2020-4-8 10:11:38 来自手机 | 显示全部楼层
{"replyTo":"","text":"I hated it","replyToPid":0}
发表于 2020-4-8 10:13:26 来自手机 | 显示全部楼层
{"replyTo":"","text":"It’s an acquired taste. I only use my occasionally, not constantly. For relief. Works that way for me","replyToPid":0}
发表于 2020-4-9 03:51:19 来自手机 | 显示全部楼层
{"replyTo":"","text":"Lol. I just got one the other day. I used it for 10 minutes, put it back in the box and returned it. Made me feel like I was sitting lopsided.","replyToPid":0}
发表于 2020-4-8 15:10:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"I thought it was comfortable, at first. Eventually, it just felt like the seat. ","replyToPid":0}
发表于 2020-4-8 18:15:13 来自手机 | 显示全部楼层
{"replyTo":"","text":"I have one and I dont use the cover for to be able to stretch it fo me and cover it with a towel.  Its a back saver for me. You just have to try it for yourself","replyToPid":0}
发表于 2020-4-8 20:03:17 来自手机 | 显示全部楼层
{"replyTo":"","text":"imo I like mine. I don't weigh much and I am not sure if it would be of any use to a heavy-set person. I have the bigger wider version. The smaller one was annoying. All versions could use some way of anchoring it to the seat because it slides off the seat every time you get in and out of the truck. Which for me is not a real concern. The only problem I can see for some shorter people would be that it places you from the floor higher and the back of your legs will rest against it which of course after hundreds of miles will cut off your circulation slightly to your legs. All drivers should have their seat height so that the back of their legs is got a hand thickness space between the seat and their back of their legs while their feet are placed flat on the floor for proper continuous circulation.","replyToPid":0}
发表于 2020-4-9 07:36:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"bought one it's on the lawnmower at home. Dont waste your money","replyToPid":0}
GMT+8, 2026-2-12 06:11 , Processed in 0.092682 second(s), 24 queries .
