查看: 199|回复: 25
fuel tax
 楼主| 发表于 2020-4-7 22:29:03 来自手机 | 显示全部楼层 |阅读模式
{"text":"NVM, fuel purchasing strategies, can I hear yours?","videos":"[]","link":"{}","pics":"[]","canComment":true,"externalShare":false}
发表于 2020-4-8 00:22:10 来自手机 | 显示全部楼层
{"replyTo":"","text":"Ya, get fuel before you run out.","replyToPid":0}
 楼主| 发表于 2020-4-8 12:04:18 来自手机 | 显示全部楼层
{"replyTo":"","text":"the word is knowledge 👌, and I'm flattered you think acuseme is the only intellectually sophisticated enlighten individual on TP, but no, there are more of us than just him.","replyToPid":0}
发表于 2020-4-8 06:46:34 来自手机 | 显示全部楼层
{"replyTo":"","text":"Independent operator/small fleet owner.","replyToPid":0}
 楼主| 发表于 2020-4-8 16:18:36 来自手机 | 显示全部楼层
{"replyToPid":353398,"replyTo":"
943163 发表于 2020-04-08 04:54:08 This comment has been deleted
","text":"you can try and explain how dum you are a million times, I get it. if you paid your taxes already you don't have to pay it. Revolation...😂😂😂😂. That's also what a tax return is, that's taxes you paid over and they give it back to you as if it's a reward.\n\nI'll explain it to you once, if you over pay in fuel tax at the pump in one state, that money goes to pay the state you drove in that you didn't pay fuel tax. if the amount of taxes paid at the pump doesn't equal to the fuel burned in each state, you pay extra when you file your IFTA to make up the difference.\n\nthere is no offsetting to avoid paying fuel tax.\n\nidk what happened to acuseme, my guess is he found something more productive to do than to converse with a bunch of Neanderthals."}
 楼主| 发表于 2020-4-8 12:14:30 来自手机 | 显示全部楼层
946573 发表于 2020-04-08 04:13:13 If I tell you your pattern you would change it up.
","text":"case dismissed, you're debarred.","replyToPid":353384}
发表于 2020-4-8 15:22:41 来自手机 | 显示全部楼层
945420 发表于 2020-04-08 03:39:46 the effects linger, sometimes you don't exhibit symptoms for weeks. go back and check the list of guys you've teamed with.
","text":"I guess you would know !!","replyToPid":353362}
 楼主| 发表于 2020-4-8 12:51:53 来自手机 | 显示全部楼层
{"replyTo":"","text":"I already know you think I'm acuseme because of my vitriolic disdain for Republicans, but I assure you I am not he.","replyToPid":0}
发表于 2020-4-8 12:26:03 来自手机
945420 发表于 2020-04-08 04:04:18 the word is knowledge 👌, and I'm flattered you think acuseme is the only intellectually sophisticated enlighten individual on TP, but no, there are more of us than just him.
","text":"Your stupidity is what gives you away. You have no intelligence,sophistication,enlightenment. Your transgender study/liberal arts degree does not make you intelligent.","replyToPid":353378}
支持 1 反对 0
发表于 2020-4-8 12:15:05 来自手机
945420 发表于 2020-04-08 04:14:30 case dismissed, you're debarred.
","text":"ok asscumoneme","replyToPid":353385}
支持 1 反对 0
发表于 2020-4-8 12:06:13 来自手机
","text":"quit lying you are asscumone. It's pretty darn obvious","replyToPid":353378}
支持 1 反对 0
 楼主| 发表于 2020-4-8 05:58:41 来自手机 | 显示全部楼层
943163 发表于 2020-04-07 16:22:10 Ya, get fuel before you run out.
","text":"doesn't surprise me, company driver.","replyToPid":352924}
发表于 2020-4-8 06:49:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"pump n run","replyToPid":0}
发表于 2020-4-8 06:54:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"take the pump price and subtract the state fuel tax. that is your real price to compare different truck stops in different states.  ideally you want a low pump price in a high tax state","replyToPid":0}
 楼主| 发表于 2020-4-8 06:59:02 来自手机 | 显示全部楼层
942540 发表于 2020-04-07 22:54:45 take the pump price and subtract the state fuel tax. that is your real price to compare different truck stops in different states.  ideally you want a low pump price in a high tax state
","text":"yes, but it's a lot of work, any resources you use? I would rather sleep for an hour than save $10 in fuel.","replyToPid":353184}
 楼主| 发表于 2020-4-8 06:59:38 来自手机 | 显示全部楼层
943163 发表于 2020-04-07 22:46:34 Independent operator/small fleet owner.
","text":"/ big bull shatter","replyToPid":353178}
发表于 2020-4-8 07:13:16 来自手机 | 显示全部楼层
{"replyTo":"","text":"lmao...whatever floats your boat, kid.  So, taking the pump price and subtracting the states fuel tax is a lot of work huh?? LMGDFAO You'd never make it as an O/O or especially a I/O.  But here's a tip anyway,  if you plan a route right and plan your fuel stops right. you can make it to where you won't have to pay any IFTA through the states you ran.  But being that simple subtraction is too much work, that what I just told you would probably make you want to quit.","replyToPid":0}
发表于 2020-4-8 07:18:58 来自手机 | 显示全部楼层
945420 发表于 2020-04-07 22:59:02 yes, but it's a lot of work, any resources you use? I would rather sleep for an hour than save $10 in fuel.
","text":"landstar has an app landstarone (if you happen to be landstar)   if you run a regular route you could build a spreadsheet to speed things up. buying fuel correctly saves hundreds possibly thousands of dollars per year","replyToPid":353186}
GMT+8, 2026-2-12 07:53 , Processed in 0.079563 second(s), 24 queries .
