查看: 596|回复: 36
every time I step out this truck.
 楼主| 发表于 2020-4-6 20:17:17 来自手机 | 显示全部楼层 |阅读模式
{"text":"","videos":"[]","link":"{}","pics":"[{\"description\":\"\",\"height\":1472.0,\"name\":\"\",\"url\":\"\",\"width\":1104.0}]","canComment":true,"externalShare":false}
发表于 2020-4-6 22:05:45 来自手机 | 显示全部楼层
{"replyTo":"","text":"shows how uneducated you and my  country man are ; the mask does not prevent the WEARER (you) from contacting a $&@ thing, the mask is intended for the sick people to wear to LOWER the spread of infection to the environment/and other non infected people","replyToPid":0}
回复 支持 6 反对 5
发表于 2020-4-6 23:20:48 来自手机 | 显示全部楼层
{"replyTo":"","text":"secondly your fashion statement nike shows how even more unintelligent you are; because if you re-wear a mask  it is doing even less good then before or actually storing sweat; bacteria; and mold spores from spring time air; to them live happily on the petri dish of your face and nose to breathe in; ","replyToPid":0}
回复 支持 6 反对 4
发表于 2020-4-6 20:23:12 来自手机 | 显示全部楼层
{"replyTo":"","text":"Where is the hole?","replyToPid":0}
回复 支持 8 反对 2
发表于 2020-4-6 22:48:04 来自手机 | 显示全部楼层
{"replyToPid":0,"replyTo":"","text":"SMH"}
回复 支持 4 反对 3
发表于 2020-4-6 22:54:23 来自手机 | 显示全部楼层
{"replyTo":"","text":"If it's not going to protect a truck driver , Larry bobs words , then what good would those types of masks do a healthcare professional ?? ","replyToPid":0}
回复 支持 5 反对 1
发表于 2020-4-6 23:43:30 来自手机 | 显示全部楼层
{"replyTo":"","text":"this is a self created- man made circle that will never end; because after that very predictable release lock down period they will scare you into the next whatever they have lined up solution ","replyToPid":0}
发表于 2020-4-6 23:35:39 来自手机 | 显示全部楼层
{"replyTo":"","text":"alllllll those (useless organs) that scientist say proves evolution (because they dont know what they do) apendix, pancreas, gall bladder that they have removed from several of my old family mamebers allll those organs combined with the liver can screen and filter your body very very well when allowed to fast and bring nothing new into the body while fasting ; this includes. but not limited to chemicals, growth hormones , pesticides, fertilizers, antibiotics in the foods we eat; dont , fasting combined with breaking a little sweat willlll get you way farther than ANOTHER STORE BOUGHT REMEDY FROM NIKE","replyToPid":0}
发表于 2020-4-6 23:30:50 来自手机 | 显示全部楼层
{"replyTo":"","text":"i have a old handkerchief that i keep in my pocket to pretend to throw on in case im in a place that has nut bars or a city law forcing it, but no way in $&@ am i going through life where spring has just barely broken out with my face covered up with or without the fashion statement nike; for the people unscared whatever; if your actually scared enough for a mask like that you should have 2-4 other more important check lists BEFORE YOU. reach masking , 1) eat a lil less meat; 2) eat a proper amount of 2-3 fresh fruits and vegetables per day try to eat those fruits and vegetables of different colors 3) get a nice dose of healthy outside air per day (not while working) doing a job or work or unloading pallets or tarping is not excersise ; your body releases unknown and not understood chemicals when you excersise with pleasure in the sun baskwtball; biking, foorball, walking to break a sweat;  4) going 24 hours fasting without food or drinks except little bit of plain water         ","replyToPid":0}
发表于 2020-4-6 22:52:15 来自手机
{"replyTo":"","text":"Is that a jock strap?","replyToPid":0}
支持 3 反对 0
发表于 2020-4-7 00:37:24 来自手机 | 显示全部楼层
{"replyTo":"","text":"I simply said if it's not going to save a trucker , hows it gonna save a healthcare pro ! And with your logic the mask that pink man has on doesn't help protect from jack sheet !! So think about it , if it doesn't protect from jack sheet for the trucker , how does it work for a healthcare pro that is right in the middle of the worst of it ?? I may be uneducated , I can admit that , I dropped out cause too many döng eaters where I went to school , but you logic is whacked !!","replyToPid":0}
发表于 2020-4-6 22:56:04 来自手机 | 显示全部楼层
{"replyTo":"","text":"Unless the said healthcare pro already had covid 19 !!","replyToPid":0}
发表于 2020-4-6 22:57:44 来自手机 | 显示全部楼层
{"replyTo":"","text":"And how do you know pink man doesn't have covid and he is actually trying to protect the populace ??","replyToPid":0}
发表于 2020-4-6 23:29:28 来自手机 | 显示全部楼层
824549 发表于 2020-04-06 15:20:48 secondly your fashion statement nike shows how even more unintelligent you are; because if you re-wear a mask  it is doing even less good then before or actually storing sweat; bacteria; and mold spores from spring time air; to them live happily on the petri dish of your face and nose to breathe in;
","text":"Natural selection perhaps !?!?","replyToPid":352559}
GMT+8, 2026-4-18 06:36 , Processed in 0.103011 second(s), 24 queries .
